Car starts the Stalls immediately!
Old May 11, 2021 | 02:39 PM
Cam_McCune's Avatar
I recently bought a 91 firebird with the 3.1 I’m having a start stall issue. The issue is persistent. It will start up immediately then just stall. I’ve replaced plugs,wires, ICM, cap, button and coil.
ive also replaced the injectors with southbay. The fuel pump. Fuel filter. Replaced EGR valve and gasket. Replaced TPS and IAC. And replaced Temp coolant sensor. I’m at a loss. It has good fuel pressure. Good spark and starts up everytime just stalls immediately. What the heck am I missing?
Old May 11, 2021 | 03:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Car starts the Stalls immediately!
Can you keep it running with starting fluid ?
and if you can does a noid continue to blink ?
Old May 11, 2021 | 03:10 PM
Cam_McCune's Avatar
Yes, it stays running with fuel being sprayed through throttle body. And I haven’t tried a noid on the injector plug when it does this. You have any idea on what it could be?
Old May 11, 2021 | 03:13 PM
Engine: Lb9
Transmission: M20
Pu coil, bad ecm, wire from icm to ecm
Old May 17, 2021 | 04:54 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Will it stay running if you hit the gas?
Firebird2011
Mar 9, 2020 06:37 AM
robster186
Oct 27, 2011 08:04 PM
MFJ
May 15, 2010 11:12 AM
BthomasM
Nov 29, 2008 12:35 PM
PhantomTPI
Jul 30, 2003 07:45 AM
