What is this.. Ac related?
Old Aug 21, 2021 | 05:44 PM
Austyn Olson's Avatar
Car: 1989 base model firebird
Engine: 2.8 v6
Transmission: Automatic
My dad bent this pipe to get to the thermostat housing and no the intake manifold does not sit where it's supposed to. Can I just take this out out completely? It's the silver lines across from the thermostat housing that wrap around by the ac compressor the top line has the spindle thing on top and its the line next to it
Old Aug 21, 2021 | 06:11 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: What is this.. Ac related?
It sounds like you are referring to the fuel lines...
If that is true, you need to step away from the car and not touch anything under the hood anymore.
If you are referring to something else, the only thing I have to point out is that EVERTHING under that hood has/had a purpose. It's generally better to keep things working as intended than to just start ripping and hacking..
Old Aug 30, 2021 | 05:42 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
- Sounds like the fuel feed lines....hopefully its not too bent or punctured...you shouldn;t have to destroy / bend those to get to the t stat though.....
- not sure what this means??
- Perhaps you should point to what you are talking about? Regardless though it sounds like the fuel lines.
greg69jones
Jul 11, 2015 10:28 PM
Andrew James
Nov 1, 2012 05:16 AM
mos68x
Aug 7, 2010 10:21 PM
knight75
Jun 28, 2004 09:16 PM
