disconnected battery now firebird cant get above 2000rpm without dying HELP!
I have a 1992 3.1 firebird that I finally got running and put about 500 miles on it and decided to start fixing some of the other things wrong with the car thinking it was running perfect not a single issue so I decided to replace my window motor and disconnected the battery before doing so after i was done put everything back together and let the car do a idle relearn for about 20 min it idles good right around 800 to 900 but now when I press the gas pedal it will climb to 2000 RPM start running rich and either sound like its gonna die or will die I have no idea what to do from this point please help me out thank you!
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: disconnected battery now firebird cant get above 2000rpm without dying HELP!
is the battery tight?
Mine does similar things if the battery is loose
do you mean the battery itself or the connection to the terminals? either way I think its secure both ways
Engine: 3.4 / 5.0
Mine acted al lweird when the battery had improper contact...
yes, disconnect and try reconnect....doing the window shouldn;t affect anything....
hopefully its simple
