3.4/3400 hybrid timing issues
Old Sep 13, 2021 | 02:04 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Hey all, I'm not sure if this belongs here or if the DIY-OROM forum would be better but I figured I'd start here as its v6 related.
I finally got my 3.4/3400 hybrid all together and tried to start it. It would run for about 10 seconds before dying. After a bunch of playing around we(my father and I) dropping the initial spark advance setting to 0 and now it'll run but it still sounds like it has too much spark advance.
at idle it runs about 25-26 defrees advance and that climbs to 36ish degrees by 3500 rpm.
Will dropping the main spark advance table help bring the timing down more?
Old Sep 13, 2021 | 02:23 PM
Re: 3.4/3400 hybrid timing issues
I forgot to specify this is with the BAWX mask
Old Sep 14, 2021 | 02:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
How are you checking the at-crank timing?
RBob.
Old Sep 14, 2021 | 03:00 PM
RBob.
I'm using Tunerpro to see what the ecm is seeing for timing
Old Sep 14, 2021 | 05:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The ECM isn't 'seeing' any timing. That is a commanded value. Doesn't mean that is what is at the at-crank timing.
When you end up with a timing light on the crank, be sure it is a regular one. NOT a dial back as they don't work with a DIS system.
Since you are running BAWX, a distributor calibration on a DIS system, you need to change three parameters:
Code:
L8015    FCB    28        ; 9.9ø inital SA (N * .352) [spark reference angle]
L801D    FDB    0171        ;  60.1ø, max SA allowed
L801F    FDB    65507        ; -10.2ø, min SA allowed
Set the initial SA to 70° BTDC
Set the maximum SA to 0° BTDC
Set the minimum SA to -66°BTDC
Will likely need to modify the XDF for that last parameter...
There is more information in this thread, but really need to read it all and dig out what is relevant.
https://www.thirdgen.org/forums/v6/5...ighlight=level
RBob.
Old Sep 14, 2021 | 06:03 PM
RBob.
oh ok. I didn't know that.
I will read that link thank you
Old Sep 14, 2021 | 06:12 PM
Rrob question. I see in that post, that you mention using $6E. That's the XDF file, right? Would that be better versus the 88 XDF im using currently?
Old Sep 14, 2021 | 07:12 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
That's the mask, you can't use an XDF for a different mask for your BIN, you'll get jumbled data at best.
Stick with the XDF you have and change the parameters with those names.
Old Sep 14, 2021 | 07:16 PM
ok thank you
Old Sep 18, 2021 | 12:53 PM
Code:
RBob.
Ok so I'm either a moron or I'm missing the obvious. Where do I find the minimum and maximum spark advance settings? I can't find anywhere to edit these numbers
Old Sep 19, 2021 | 08:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Doesn't look like they are in the XDF file. Since they are rarely changed that is likely why. Can either add them or hand edit the BIN via the hex editor
RBob.
Old Sep 19, 2021 | 03:54 PM
There might be a more defined XDF as well. I know Robert Saar was trying to make very complete XDFs for a while. Check on gearhead-efi.com.
Old Sep 19, 2021 | 05:56 PM
Thank you Six_Shooter, I'll do that
RBob.
Rrob do you have a link to a how-to on editing or adding to the xdf? I've never tried any of that before
Old Sep 22, 2021 | 04:44 AM
Rrob I stumbled upon some guys talking about using $a1 with a BAWX bin in a corsica. They never posted if it worked.
Have you heard of anyone else using this?
Old Oct 2, 2021 | 11:31 PM
Ok, thank you both. I'm definitely getting somewhere. Between 1200 and 5000 rpm it runs great and sounds great.
on start up though, it shoots black smoke and it won't run below 1100-1200 most of the time. Occasionally I can get it down to 1000 rpm then it'll suddenly die.
these rpm ranges are all display values in tunerpro dashboard.
I'm going to check the iac tomorrow to see if its plugged.
Old Oct 3, 2021 | 09:42 PM
I'm going to make a suggestion that will at least allow the engine to start and run, but you may need to flip back to what you're using in the long run due to actual vehicle setup.
Anyway, grab a FWD bin file and upload it to your Ostrich or EEPROM (I don't recall which way you're tuning), this will have everything correct settings for the ignition. to verify that side of things.
Also do you have larger than stock injectors? IIRC stock for the bin file you're using is about 19 lbs/hr, if you're using larger injectors you can experience similar symptoms to what you are seeing. If so, you will need to make some changes to account for the injectors.
Old Oct 5, 2021 | 05:03 PM
Thats a good idea Six_Shooter I'm going to do that, thank you.
I'm using tuneroro v5. Ya according to the part numbers, they're 17lb injectors and the tune was set of 15lb so that helped. Once i figured out that by adjusting the "spark advance" in the older $88 i was actually adjusting the "spark angle reference" in the newer $88 tune i git from gearhead_efi.
Now its running and idling but not yet correct. Under heavy acceleration, its got a spark knock. Its either too lean or the timing is still too advanced
Old Dec 4, 2021 | 06:19 PM
I got it running, smoking terribly but running. Today I tried unplugging the injector to see if it was more excess fuel or oil in the cylinder. I cleaned and dried the plug then ran the car for about 30 seconds. The plug was soaked with oil. I'm currently letting it sit with marvel mystery oil with the hope that the rings are just struck.
any other things to look for before I pull the motor back out?
Old Dec 6, 2021 | 02:59 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
What do you have in the motor?
Not a hybrid expert but I recal lseeing that you need to get the 3.4 block, and change to i think it was 3400? Pistons, or the compression would be wrong?
Old Dec 7, 2021 | 02:27 AM
1989karr
Its a 3.4l block bored .010 over to straighten out the bores. The pistons are custom made forged jobs made to the 3400 piston specs. The crank and rods are factory either 3.4 or out of the 3400. I'm not sure which, I bought the block already honed and most of the parts as a package deal many years ago.
the cam is a Delta cams
Old Dec 7, 2021 | 06:40 PM
1989karr's Avatar
Engine: 3.4 / 5.0
did you check basic things like compression / add oil to compression, fuel pressure etc?
Old Dec 7, 2021 | 07:38 PM
fuel pressure is 42 with te engine off, around 38 with the engine running. Compression in 1,2,3,5and 6 is all 150-155. Number 4 is 190 but its leaking oil in, so that doesn't count.
what do you mean be "add oil to Compression "?
Old Dec 8, 2021 | 11:15 AM
1989karr's Avatar
Engine: 3.4 / 5.0
compression seems good!
i meant a wet compression test...couldn't think of the word.
Given that the components are correct physically/ mechanically.... sounds like timing?....could it be that the ignition module may be bad? I think it was your build that you used the old one from the donor vehicle??
You description matches my old FWD 2.8 when the ignition plate / module under the coils went bad, so even if you get the timing correct etc.. its still won't run correct... those are known at least on the older ones to crap out.
TPI-Formula350-
Mar 9, 2011 09:34 AM
vetteboy86
May 11, 2007 07:28 PM
IroczInOz
Jul 1, 2006 09:29 PM
1bad91Z
30
Dec 2, 2003 08:05 PM
Matt87GTA
Apr 25, 2002 01:44 PM
