Total Timing
Old Mar 7, 2011 | 08:09 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Total Timing
just looking to learn about tuning a bit more. Just have a few questions. Is total timing the sum of the bins base timing in the constants section of tuner pro plus the numbers in the 208 row of Spark Advance Table. I'll list a few examples and you guys tell me if I'm understanding this correctly.
first example
Tables/functions
Spark Advance Table
208 Row
4800 26.02+ 8.09 base timing= 34.11 total timing??
4400 26.37+ 8.09 base timing= 34.46 total timing?
example#2
Tables/functions
Spark Advance Table
208 row
4800 22.85+8.09 base timing=30.94 total timing
4400 23.20+8.09 base timing=31.29 total timing
If my understanding is correct please let me know..thank you
Old Mar 8, 2011 | 12:39 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Total Timing
that is correct
Old Mar 8, 2011 | 06:07 PM
Car: 89 Formula 350
Re: Total Timing
Originally Posted by old z mzn
that is correct
are you sure, another member on the site emailed me and said i was incorrect. He said it was spark advance table 208+PE mode spark advance vs. RPM valve..He said the base timing doesnt coming into the formula and isn't added to the main spark advance table????
Old Mar 8, 2011 | 07:13 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
Re: Total Timing
do a search on total timing
ex. base timing 6 deg. + spark advance 24 deg.= 30 deg. total timing
pe adds timing to that
Old Mar 8, 2011 | 08:38 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
Re: Total Timing
just pulled my chip it looks like total timing is in the table. I am showing 34 @ 3200 deg. at wot pe zeroed out
i have my base set at 14 deg.
thanks found a problem in my chip
Old Mar 8, 2011 | 09:38 PM
Car: 89 Formula 350
Re: Total Timing
well that makes sense from what he was saying...he said he just put 0 in the PE mode spark advance and does the timing in the main spark advance table so he doesnt have to add the main spark table to the PE spark table to get total timing
Old Mar 9, 2011 | 06:47 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Total Timing
The initial/base SA is subtracted out in the ECM, but added back in by the distributor. So it has no affect on the main SA table values. Say the initial SA is set to 6* BTDC. Which is also where the distributor base timing is set.
Table look up gives 30* BTDC (ignore all other SA modifiers).
The ECM sub's out the 6* initial and programs the distributor for 24* of advance (30 - 6).
Since the distributor is set for 6* BTDC, that is the reference point to add the 24* to. So the at-crankshaft timing ends up at 30* BTDC. Same as the table value.
Head up to the Tuning Guide Book sticky, chapter 5, '8746/'8063/'7747 ECM section. SA Logic explains a lot about how the spark advance logic works.
RBob.
Old Mar 9, 2011 | 09:27 AM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
Re: Total Timing
http://support.moates.net/2009/05/07...guide-read-me/
this link should help.
ebl flash is a great way to go.
Old Mar 9, 2011 | 09:34 AM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
Re: Total Timing
wrong thread
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bellez77
Sep 5, 2015 08:39 PM
neekolzun
Aug 24, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
