Stock PROM code needed (4-digit code) for '89/305-TPI/M5
Old Apr 23, 2009 | 11:02 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Does anyone know the factory 4-digit PROM code for a 1989 IROC with a TPI 305ci w/ 5-speed?
Info would be appreciated!
Old Apr 24, 2009 | 01:51 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Stock PROM code needed (4-digit code) for '89/305-TPI/M5
In '89 IROC-Z, TPI (RPO LB9) with M5 was available with two different rear end ratios (3.08 & 3.45). From my notes the following two BCC may fit your needs.
1989 IROC-Z 305, M5, A/C & 3.45 (FED) APYS 9350
1989 IROC-Z 305, M5, A/C AUJS 3509
//RF
Old Apr 24, 2009 | 06:50 AM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
My 1989 Formula, LB9 (305 TPI), T5, 3:45 Rear, came with ANYX. I have a virgin copy of the bin if needed.
Old Apr 24, 2009 | 09:08 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
In fact I do. PM sent.
Old Apr 24, 2009 | 07:15 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
'89 5.0TPI M5 3.08 CA = ANZA (most recent).
Old Apr 24, 2009 | 09:26 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What does the CA stand for?
Old Apr 24, 2009 | 11:48 PM
RFmaster's Avatar
Car: 75 Beast
CA = the eco-**** state of Kalifornia!!! Where we can not balance budget and idiots at air resource board want to impose lower carbon fuels = $$$$ expensive.
Old Apr 25, 2009 | 01:18 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
So would the non-CA .bin be more desirable to use?
Old Apr 25, 2009 | 10:39 PM
RFmaster's Avatar
Car: 75 Beast
If you look through the years at HP/TQ ratings of all cars you'll find that CA certified cars had lower ratings and more emission control equipment to boot. You can thank for this a faceless, politically appointed group of people, with unchecked power - CARB aka California Air Resource Board. If you ever want to find a greater collection of technically incompentent people in the world, all in one place, it is this group of <insert fovoirite 'ist'> here. A lot of group think goes there and most of it is done in complete disconnect with reality, or its effects on people and economy in general.
//RF
Old Mar 9, 2011 | 06:46 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Good stuff! I am keeping this string for reference. Thanks.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
djmarch
Aug 11, 2015 10:22 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
