Idle like a rollercoaster
Old Feb 22, 2022 | 03:03 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
This is a problem a friend is having with her 3.1 Camaro. She's over 4 hours away so I can't just go round easily so I'm trying to get an idea of what could be going on.
She starts the car and the rpms sit pretty high even after the car has warmed up a bit. If she puts it in drive the rpms come crashing down and the car feels like it's about to cut out.
If she starts driving the car does indeed cut out!
My first thoughts could be the TPS? Or vacuum leaks. She can't read the codes or anything which doesn't help me either lol
Old Feb 22, 2022 | 06:15 AM
Whitebird75's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L V6
Re: Idle like a rollercoaster
Check the timing first, but make sure you unplug the Distributor disconnect on the firewall. If the Disconnect isn't disconnected, the timing will be off by several degrees.
Also note, the #1 cylinder on the V6 is on the opposite side than a Small Block Chevy. As you are in England, I cannot identify the sides as Driver or Passenger, so it's best to check which cylinder is the leading cylinder. (Note, if the battery is in the same location as a North American 3.1 Camaro, it is generally easier to time the engine utilizing the #4 spark plug wire. This prevents the timing light pickup wire from crossing the serpentine system. As #4 cylinder fires 360 degrees out from #1 cylinder, the readings on the balancer will be the same.)
Old Feb 22, 2022 | 06:49 AM
cosmonautpg's Avatar
Car: 1992 Camaro RS
Engine: LH0 V6
Transmission: A4
FWIW, this was one of the first same exact problems I had to diagnose and fix on my 3.1 years ago. Turned out there was a 2-3 cm hole in a vacuum line that ran up to the injector assembly at the top of the engine — it was hard to find but once I replaced that line (among others) this went away.
Tell your friend to run her hands along ever vacuum line that she can see, using a flashlight to check for holes and cracks. In particular, any lines which might make consistent contact with the engine because of how they’re routed.
Not sure if this is the *only* problem but you’ll find this is one of the most common solutions which is easy to diagnose with some time. Good luck!
Cordero51
Mar 30, 2014 11:01 PM
Matro
Jul 8, 2013 09:15 AM
NiteStar
Nov 14, 2010 02:53 AM
D BERRY
Apr 17, 2007 06:21 PM
thunder85
Apr 25, 2004 10:35 PM
