EGR Connector
Old Feb 5, 2023 | 11:14 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
EGR Connector
Working on my Code 32 and found when I took the EGR Valve off that the connector is mostly falling apart and one pin inside the EGR valve is bent over a bit. So, I need to get a new connector. Anybody know where I can order one or am I stuck looking in Pick n Pull places? Anybody know what other vehicles and years that use the same valve and connector as 90-92 Camaros and Firebirds are non existent in my area yards.
Thanks...
Old Feb 5, 2023 | 11:52 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR Connector
Might ask @firebirddude142 if he has the connector for the 3.1L egr valve.
Old Feb 6, 2023 | 12:24 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: EGR Connector
This is the electronic solenoid valves (digital EGR Valve so no vacuum lines). I found an Airtex part number but only one company listing it and it doesn't look like they carry the connector anymore. At least on their site they showed a list of vehicles from GM (Buick, Chev, Olds, and Pontiac) that are supposed to use the same one. I have a Pick n Pull just up the freeway that has a 94 Olds Cutlass Ciera station wagon and a 94 Buick LeSabre listed that may have one. Heading up there in the morning (Monday) to see if there is a good used connector.
Old Feb 6, 2023 | 12:49 AM
Engine: Lb9
Transmission: M20
Re: EGR Connector
List of vehicles that use that egr
Buick
  • 94-95 Century (submodel: Custom, Special)
  • 88-90 Electra
  • 91-93 LeSabre
  • 88 LeSabre (submodel: Base, Custom, Limited) Eng. VIN: C
  • 89-90 LeSabre (submodel: Base, Custom, Limited)
  • 91-93 Park Avenue
  • 88-91 Reatta
  • 91-93 Regal
  • 90, 94-95 Regal Custom
  • 90 Regal (submodel: Gran Sport, Limited)
  • 88-93 Riviera
  • 94-95 Skylark (submodel: Custom, Gran Sport, Limited)
Chevrolet
  • 90-95 Beretta Base
  • 90-93 Beretta GT
  • 91-93 Beretta GTZ
  • 90 Beretta Indianapolis 500 Pace Car
  • 94-95 Beretta Z26
  • 93-95 Camaro Base
  • 90-92 Camaro RS
  • 92 Camaro RS Heritage Edition
  • 90 Cavalier Base
  • 90-94 Cavalier (submodel: RS, Z24)
  • 90 Celebrity (submodel: Base, Eurosport)
  • 94-95 Corsica Base
  • 90-93 Corsica LT
  • 90, 92 Corsica LTZ
  • 94-95 Lumina
  • 91-93 Lumina Z34
  • 90-93 Lumina (submodel: Base, Euro)
  • 92-93 Lumina APV Base
  • 92 Lumina APV CL
  • 93 Lumina APV LS
  • 95 Monte Carlo
Oldsmobile
  • 92-93 88 (submodel: Royale, Royale LS) Sedan
  • 89-90, 92-93 98 Regency OE No. 17091147
  • 88 98 (submodel: Regency, Regency Brougham, Regency Touring) With U.S. Emissions
  • 89-90 98 (submodel: Regency Brougham, Regency Touring) OE No. 17091147
  • 91-93 98 (submodel: Regency Elite, Touring) OE No. 17091147
  • 94 Achieva SC
  • 94-95 Achieva (submodel: S, SL)
  • 94-95 Cutlass Ciera Base
  • 94 Cutlass Ciera (submodel: S, SL)
  • 94 Cutlass Cruiser (submodel: Base, S, Special Edition)
  • 93-95 Cutlass Supreme
  • 92 Cutlass Supreme S
  • 90-91 Cutlass Supreme SL
  • 90-92 Cutlass Supreme (submodel: Base, International)
  • 88-91 Delta 88 (submodel: Royale, Royale Brougham) Sedan
  • 92-93 Silhouette Base
  • 88-92 Toronado
Pontiac
  • 90 6000 (submodel: LE, Special Edition) FWD
  • 91 6000 (submodel: LE, Special Edition)
  • 89-93 Bonneville
  • 88 Bonneville (submodel: LE, SE, SSE) Eng. VIN: C
  • 90-95 Firebird Base
  • 94-95 Grand Am (submodel: GT, SE)
  • 92-95 Grand Prix
  • 90 Grand Prix (submodel: LE, SE, STE) Naturally Aspirated, Without Vacuum Connector
  • 91 Grand Prix (submodel: GT, LE, SE, STE)
  • 91, 94 Sunbird LE
  • 93 Sunbird LE Value Leader
  • 91-94 Sunbird (submodel: GT, SE)
  • 90-91 Tempest Base
  • 91 Tempest LE
  • 93 Trans Sport Base
Old Feb 6, 2023 | 09:04 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: EGR Connector
Wow, thanks for posting the list. It has a lot more cars on it than the short list that I found. Off to the Pick n Pull yard....
Old Feb 6, 2023 | 09:16 AM
Engine: Lb9
Transmission: M20
Re: EGR Connector
I just used egr application list, good luck on the search
Old Feb 7, 2023 | 10:49 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: EGR Connector
Success on finding a connector! Got to the Pick n Pull yard right after they moved the car (Beretta) that I went to check to the crusher so searched through the remaining cars and found two with the digital EGR valve. I pulled my EGR valve off and bench tested it. Only one of the three solenoids is working. I also found that my connector after pulling the wire loom (melted) and tape off was in really, really bad shape with bare wires. I ordered a new EGR valve to arrive today and picking up some extra wire so I can splice in extra length on the pigtail I got from the donor car to make it easier to route. I found this pdf elsewhere in the forums which helped in bench testing but this is for a 3.4L and the wire colors are different on my car.
File Type: pdf
Old Feb 7, 2023 | 11:23 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: EGR Connector
No more Code 32..... Just took the car out for a test drive.. Put about 20 miles on it and no more Code 32 at all.. So, in summary, I had to fix some major exhaust leaks, replace the plug to the EGR, and put on a new EGR.. I have been fighting the problem for years and all along I think it was mostly the frayed wires in the EGR connector which I couldn't see because of the tape and wire loom over it. My guess is that the 3 signal lines were shorting together and that led to the EGR plugging up two of the three solenoids... If you haven't solved your problem, check the EGR plug wires under the cap...
Old Feb 10, 2023 | 10:35 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: EGR Connector
Its been a couple of days and about 3 hours worth of driving time. All good with the EGR. Code 32 is resolved.
billym81
Dec 18, 2016 07:35 PM
89transam*pearl
Sep 24, 2014 08:14 PM
Mark Vargus
Aug 3, 2014 10:42 AM
WilliamsJ91
May 17, 2011 08:00 AM
