2.8 Been sitting a while
Old Feb 13, 2023 | 08:42 AM
Amps1956's Avatar
I have 87 2.8 been sitting I'm guessing for a few years fuel pump actually still working and it turns over but no spark i am planning on ditching this motor but I would like to be able to move car around till I'm ready I am not to familiar with these this is my 1st bird but what should I look for to start with like I said appears to get fuel no fire thanks in advance
Old Feb 16, 2023 | 11:33 AM
Amps1956's Avatar
Re: 2.8 Been sitting a while
No body ??
Old Feb 19, 2023 | 02:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, I'm doing the same; my 86 2.8 has sat for about 6 years. Time goes by so fast! Had to replace my fuel pump, now I have spark but think my fuel's gone bad.
Do you know why the car was parked for years? That could be a clue too. Or did anyone work on it since it was parked? (#1 cylinder on a 2.8 is front passenger cylinder, not like a v8)
No spark could be a few things, start easy first. Find the spark coil, there's a black 2-wire connector that goes to the spark module in the distributor (picks up the pulses and says when to fire the coil), and a gray connector that's basically +12 and ground (power supply for the coil). Unhook the gray connector, then turn the key to "on" (not cranking), and put a voltmeter between the gray connector's pink/black wire (+) and battery negative. Does the meter say +12 volts?
Old Feb 19, 2023 | 10:57 PM
Amps1956's Avatar
I got it from a guy that took apart to paint then lost interest he said it ran but has been sitting several years
Additivewalnut
Sep 28, 2022 06:38 PM
maroe624
Jun 13, 2018 12:23 AM
hydrolic144
May 4, 2008 03:27 PM
ur7x
Jun 23, 2007 12:42 AM
