3.1 fuel return line question
Old Apr 2, 2023 | 02:05 AM
Riscy's Avatar
Hi All,
I have a ‘92 Camaro TPI intake that I’m going to install on a 3.1L engine in an ‘88 S10 Blazer. ECU will be a Holley Terminator-X.
Hey all… what is the funky “canister” in the middle of the return hard line (mounted to the front of the manifold)? It almost looks like a fuel filter, but it seems to be bonded/welded to the return line.
Any help is greatly appreciated - thank you!!
Old Apr 3, 2023 | 11:24 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: 3.1 fuel return line question
Sounds like you're describing the fuel damper, which is in the feed line...
Post a picture so that we can see exactly what it is you're asking about.
Old Apr 3, 2023 | 07:08 PM
Riscy's Avatar
Sorry - you are absolutely correct; it is in the feed line!
Im reading that the damper do smooths out injector-caused pulses in the feed line, potentially reducing noise. Is that all it does - quiet things down? Is it replaceable (does that cap just pry off?)
thank you!
tompumped
May 29, 2018 05:18 PM
chanrahan
Carburetors
Aug 31, 2017 07:29 PM
Sttn89
Mar 1, 2012 11:08 PM
coolrimsatleast
Dec 4, 2006 11:43 PM
