ANYONE WITH A 3.1 AND 5 SPEED please come in
Old Jan 21, 2002 | 08:32 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i need to know where you idle at
and at what RPM you do 50, 55, 60, 65 MPH in 5th gear
please only post if you have stock gears
thanx guys
cuz my tach is all screwed up
Old Jan 21, 2002 | 09:22 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
best i can remember, my 91 (3.1 w/ T5) would idle between 1.2k when cold and 800 when warm. i dont remember where 50+ was. i thnk it was bout 2k in 5th. i hope that helps.
mike (loomdog)
Old Jan 21, 2002 | 10:13 PM
89BlackBirdKid's Avatar
I have an 89 but I think the gears are the same and I cruise 60 at about 2150 rpm or so. hope this helps
Old Jan 22, 2002 | 11:32 AM
KED85's Avatar
It should be NEXT TO IMPOSSIBLE for your tach to ever screw up.
It's electric. It reads an electric signal. THE ONLY WAY it can honestly screw up is the source of the signal. Or you bent the needle.
Bad worn wires are a prime source. Have you removed your instrument panel lately? That may jar connection, too.
Old Jan 22, 2002 | 11:50 AM
Camaro_hunter_d's Avatar
Mine Idles around 850ish... 50 2500 ish.. others I put in the other thread.
Old Jan 23, 2002 | 12:22 AM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
I idle at about 750 to 800 at normal operating temp. The only thing I can remember in 5th is if I am going 45 mph than the tach is at 1500 rpms. Sorry I'm not much help.
Elephantismo
Feb 13, 2019 12:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
cking99
Sep 22, 2015 11:33 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
