91 3.1l v6 Doesn’t like to idle when hot
Old Sep 4, 2023 | 07:53 PM
91v6's Avatar
Hello everyone, I have a 1991 3.1l v6 firebird that doesn’t like to idle when it starts to get around 160 degrees. I am looking for any help on what this may be.
I have replaced the following:
______________
•TPS
•IAC
•Coolant temp sensor
•MAP sensor
•Thermostat
•Ohms on all injectors read 12.4-12.8
•Fuel pressure regulator
•Entire fuel rail
•Starter
•Knock sensor
•Spark plugs
•Spark plug wires
•Timing chain and gears
•ICM
•Wiring harness for injectors
_____________________
We have also tested it with a timing light and that is good. We bought the car not running. The fuel pump doesn’t work, so we installed a temporary inline fuel pump under the hood. I believe it is rated 50-60 psi. Any help is appreciated. Thanks!
Old Sep 8, 2023 | 03:37 PM
southbay08's Avatar
Re: 91 3.1l v6 Doesn’t like to idle when hot
were the injectors tested when they are hot?
Old Sep 9, 2023 | 12:12 PM
91v6's Avatar
Southbay: No they weren’t, I have read that they drop in ohms when hot though. The injectors are new so I find it unlikely but I can try it if needed.
Old Sep 9, 2023 | 02:05 PM
southbay's Avatar
That's correct. Sorry thought they were stock
Ctroup21
Jul 27, 2023 12:07 PM
Shelly2015.
Nov 13, 2018 02:17 PM
morrow
Jun 24, 2013 09:49 PM
BellaBird
Aug 30, 2010 11:48 AM
sscamaroracer87
Sep 10, 2009 02:47 PM
