Swap is completed.............
Old Jan 23, 2002 | 07:26 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
my swap is completed after two weeks of no starting from my car. I found out the timing was off 180° 5 days ago so i fixed that and i was still off a tooth, so i fixed that and now it runs pretty good. All though i kinda turned the car into a fountain because I pluged a coolant temp sensor hole with a spigget and a rubber cap forgetting that coolant is under pressure, so i took it for a test drive down my dead end street and after turning around power sliding i got a rush of coolant on my widshield. Open the hood i had coolant going throught the plug squirting out like a fountain. Now for the good news. The new is I think i gain about 25-30hp the car feels much stronger, but will have to see when i take it on the road tonight, then i'll report my findings.
Old Jan 23, 2002 | 08:29 PM
j166a99's Avatar
sorry if i didnt catch on, but what was swapped?
good to hear of the HP increase!
...me want some too!
Old Jan 23, 2002 | 09:30 PM
fiream's Avatar
Engine: 400HP 350
Sorry for the confusion. What i did was swap my stock 2BBL. intake for an Edelbrock Performer 2BBL. intake. I also swap my distributor out for a vacuum advance one along with a vacuum advance carb. Lots more power.
Old Jan 23, 2002 | 09:32 PM
fiream's Avatar
Engine: 400HP 350
another
Old Jan 23, 2002 | 09:35 PM
fiream's Avatar
Engine: 400HP 350
oops
Old Jan 24, 2002 | 12:01 AM
KED85's Avatar
WAY EXCELLENT!
I learned about distributors the hard way too!
Now, It seems so easy, right!!
Old Jan 24, 2002 | 09:36 AM
fiream's Avatar
Engine: 400HP 350
I guess you could say its easy.
Old Jan 24, 2002 | 09:37 AM
fiream's Avatar
Engine: 400HP 350
Another pic
Old Jan 24, 2002 | 08:40 PM
KED85's Avatar
Distributor drop ins
First time I had to do that mission,
I ended up having the car towed to a place and having them bump start/turn over engine to TDC, then they dropped it in.
You figured yours out, at home.
Once you discover it, it is easy.
Especially with a remote start switch you make (I did that).
Old Jan 24, 2002 | 08:46 PM
fiream's Avatar
Engine: 400HP 350
I got it in right, it runs pretty good, i've got some hesitation to fix and maybe a slight vacuum leak somewhere but other then that a whole lot more power.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
