Zero volts to TPS pin connector
Old Sep 29, 2024 | 01:47 PM
Coupe's Avatar
Car: 86 Camaro sport coupe
Engine: 2.8l v6
Transmission: Automatic
(86 sport coupe 2.8l v6)
I recently installed a new TPS and set the voltage just like all the YouTube videos say to do it. Everything worked as it should and was previously getting all the correct voltages. I had an oil pressure sensor go bad and start leaking under pressure so I swapped it out and now I’m getting 0.01 on the grey pin with the key turned on and the black lead on the negative battery terminal. Any ideas??
thanks
camaro87-alex
May 7, 2009 03:26 AM
HaulnSS
May 3, 2008 04:26 PM
trueburton
Jul 28, 2005 08:31 PM
jester111
Mar 31, 2004 12:06 AM
JOHN/88IROCZ
Nov 4, 2001 10:47 PM
