Ignition coil 90 3.1
Old Jan 13, 2025 | 06:22 AM
Bluegoose95401's Avatar
My 90 3.1 bird has been a turd for some time now mpgs in the 10s and it was running rougher and rougher every time I drove it. Last time I took it out I barely made it home.
puller the old injectors swapped them with Bosch injectors new fpr cleaned up the iac. When I was running it after everything was swapped over I kept hearing this tapping. It was running cleaner ( it was so rich before your eyes would water ). But still rough. I started looking around in the dark and found the coil pack was arcing from the bottom of the pack to the valve cover.
is a factory replacement the way to go or a performance coil of some sort like an msd or accel?
Old Jan 13, 2025 | 06:48 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Ignition coil 90 3.1
A factory replacement will work just fine.
jjcuff1
Dec 12, 2013 10:53 AM
Tom91Bird
Aftermarket Product Review
Aug 15, 2006 01:18 PM
kretos
May 20, 2004 02:50 PM
akamoose
Dec 5, 2002 02:59 PM
ice775899
Apr 20, 2002 09:36 AM
