smog pump delete
Old Jan 26, 2002 | 08:44 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
smog pump delete
ok guys, after a long talk with my engine performance proffessor, he basically told me that smog pumps are useless
actually they are worse than useless cuz they rob power from the engine...........but we all know this already
lemme cut to the chase......i wanna hollow mine out........does anyone make a delete pulley for it or can i hollow it out???
lemme know guys:rockon:
Old Jan 26, 2002 | 11:35 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
I got rid of mine. My car runs better and the exhaust is louder.
Old Jan 27, 2002 | 02:23 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
How are they useless? The air helps convert Carbon Monoxide to Carbon Dioxide.
Old Jan 27, 2002 | 02:28 AM
Engine: LH0 3.1L
It also oxidizes HC's to create clean water vapor. I'd still ditch mine in a heartbeat if I could ever find a pulley.
Old Jan 27, 2002 | 07:22 AM
Mike Crews's Avatar
For the 5.7L F-Body motors, the AIR Pump delete pulley GM part number is 10186167. This part has an "ex" code (for export only), therefore you local GM dealer won't be able to order it. I ordered mine with no problem through GMPartsdirect.com. It was about $42 as I recall. It works great, and you use the stock belt.
See Ya, Mike........
Old Jan 27, 2002 | 11:26 AM
Camaro_hunter_d's Avatar
If you can't find the pully no biggie just get a shorter belt. Measure the path of the belt going the direction needed with a piece of string. The length number will translate into a belt number, or something very close(Usually within 1/2") But Air pumps do not take alot of parasitic HP, Maybe 1-2 max. I would actually keep it and find a way to convert it inso a crank case vacuum pump. It will not vreate vacuum like the 400 buck moroso but it will create some!.
Old Jan 30, 2002 | 12:47 AM
Engine: LH0 3.1L
Re: smog pump delete
Well, aren't you gonna explain why you think they are useless?
Old Jan 30, 2002 | 11:27 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Smog pumps being useless can be a fact. Because the power it takes to run the pump usually almost cancels out the gains it creates. On a larger engine it would work fine, but on our V-6 it probably almost cancels out, and on Ford Tempo's, its better to now have the pump... lol
my $.02
Old Jan 30, 2002 | 01:34 PM
Re: Re: smog pump delete
i'll answer that after someone gives me a straight answer how to get rid of mine
j/k
anyways, not trying to anybody, i forgot exactly what he told me, but it had to do with why no new cars come with them anymore, not only because they take so much power to run them but because they work rather ineffecient, because the engine now has more strain on it-------thus it cuts down on effeciency, thus using more gas---thus emitting more pollution------it was something to that effect
i'll have to go look in my notebook
Old Jan 30, 2002 | 03:22 PM
Joe_L's Avatar
Car: 1995 Z28
1991tealRSt-topGuy
Yeah my dad is a mechanic and will second that. Hence the Ford tempo runs better without; along with most other cars. Like you said, it takes more gas, and power to run it, therefore causing it to be uneffective.
Old Jan 30, 2002 | 07:34 PM
KED85's Avatar
No.
Todays current designed engines are more fuel efficent, they have less byproduct to dispose of.
All a "smog pump" does is injest extra air into a chamber to "complete" the fuel mixture burning, which (more fuel completly burnt) equals less left over fuel to eliminate by an external driven pump system.
Does it take HP, big deal. .5 to 4HP.
Can my kid grow up in cleaner breathing air, FINALLY in Los Angeles.?
Yes.
Leave it on.
You loose nothing and gain a healthier life.
Or buy a more modern car and eliminate the smog pump, that way.
Since I just visited back east, I can pass this along.
New Jersey air didn't look so pretty. Like old LA smog air. I was by Trenton and all along the Garden State Parkway to go to Conn.
I "MISSED" the Newark sewage dumps.
Keep your current air, clean. You'll never know how much you'll miss that clean air, until it's gone.
I waited 20 years for LA air to clean up. What a dream come true.
Old Jan 30, 2002 | 08:26 PM
Engine: LH0 3.1L
Re: Re: Re: smog pump delete
j/k
Most new GM cars have electric smog pumps. Also, I agree that a belt driven smog pump will cause some parasitic power loss, but REALLY......how much power could it possibly rob?
Personally, i want to get rid of mine cause the pump keeps going bad.
Old Jan 30, 2002 | 09:11 PM
ok maybe i didnt give a good reason why i want to get rid of mine.............we have engines for which very few mods are available........hence........every 1 horsepower i can get, i want to take!
Old Jan 30, 2002 | 09:14 PM
and when did i ask for anyones opinions on this matter??
this thread is totally shot in the a$$ now becuz no-one answered my simple question
i didnt ask: will i harm the air if i take the pump off?
I DID ASK: HOW DO I GET RID OF IT
Old Jan 31, 2002 | 10:41 AM
KED85's Avatar
Mike was kind enough to supply the answer, part number and way to order it.
#10186167
Order it by GMparts.com
Gaining 1 hp ain't worth $44 to me.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
