Uh oh... Is my motor going bad? Knockin?
Old Feb 10, 2002 | 02:07 PM
AntiVTEC's Avatar
Here's what happened. My car was really huffin and puffin, so i suspected timing since everything else was new. Sure enough, the the timing was at 0*, so i set it to 10*. That totaly solved all the low end huffin and puffin but now it brings a new problem.
When i'm hard on the gas, like 75% to WOT, the motor clunks. Is that knock? It kinds sounds like when someone almost stalls driving a manual and the RPMs get really low. That "clunk clunk clunk" sound. It happenes at any RPM when i'm hard on it but I don't hear it at idle, or when revving it in neutral.
Why would the sound become very apperent when I brought the timing back to where it was? Is my motor goin bad?!?! Thanks alot!
Old Feb 10, 2002 | 03:00 PM
Brian K's Avatar
Change your oil.. Move up to a SAE 30 or 5W30... Add a can of engine restore and then see if it is still knockin.. Also chaeck your Radiator fluid, and add a gas treatment to clean the injectors and raise the octane.
Old Feb 10, 2002 | 03:07 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
if u had a real knock it would do it all the time. it does it in gear at 75-wot, but not in neutral.. hmmmm.. ur flywheel may be missing teeth. that is something to defiently check, its a major PITA to check that tho.
mike (loomdog)
Old Feb 10, 2002 | 03:44 PM
I Cant Drive 55's Avatar
Just from what your describing it sounds like your timing is way too far advanced under a load and it is pinging real bad. You need to check timing when you carry your RPMs up with an adjustable timing light. I think 34* is the most you want at full advance. Your timing advance may be mess up.
Also a lean fuel mixture will do the same via vacuum leaks check your EGR and plenium gaskets.
Old Feb 10, 2002 | 03:49 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Sounds like it's knocking or pinging. Check timing again. MAKE SURE THE HARMONIC BALANCER HASN'T SLIPPED. Was your timing 0 degrees with the EST disconnected?
Also, check backup timing. With the EST disconnected, your timing should advance around 1500-2000 RPMS. If it retards or if it jumps around erratically you need to rebuild your distributor.
Old Feb 10, 2002 | 06:02 PM
AntiVTEC's Avatar
The timing is correct. I did it with the EST disconnected and its set at 10* at idle. It moves smoothly as the RPM's climb. Anothing thing i noticed today, it doesnt occur above 4500 RPM. There arent any vac leaks.
The oil i'm running is Mobil 1 Clean Drive Blend full synthetic 10w-30. I've been running the oil for bout a year now and the problem just sprung up.
Old Feb 10, 2002 | 09:09 PM
BitchinRS's Avatar
If your timing was way off you may have fauled the crap out of your plugs. Check your plugs. You may only find one or 2 that are fauled, but it will be enough to through it off. This happened a just recently. I thought some thing major was wrong. It was just my plugs.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
neekolzun
Aug 24, 2015 04:59 PM
Out-Cast
Aug 17, 2015 10:57 AM
Bradsaundry
Aug 12, 2015 12:34 AM
