1983 V6 S/e
Old Feb 15, 2002 | 01:43 PM
NuclearBlast's Avatar
1983 V6 S/e
I own a 1983 Firebird SE... It needs a little work, which I'm going to do as soon as I get the insurance $ from my other car, which I just wrecked I had a 1990 Audi VE Quattro... and I had bought the Firebird as a favor to a friend and because I've always wanted a third gen... Anyone have any suggestions as to what I should do with the car? I'll post pics as soon as I find them, along with the VIN if anyone really wants me to.
Old Feb 15, 2002 | 04:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sure; do a major tuneup. You can run through the usual "major tuneup" post of mine https://www.thirdgen.org/techbb2/sho...threadid=62882 , with the following exceptions: The plugs should be gapped to 0.035", instead of 0.045". You have a "breather filter" inside the edge of the air cleaner that you should replace. If you have an automatic trans, it's the 200C instead of the 700r4 like 84-up V6's. (I don't know about manual trannies for that year.) Your timing spec is different than the 85-up fuel injected 2.8's, and should be listed on the emissions sticker located on the inside of your hood. Your fuel filter (Purolator A736C) is inside the carb; be careful not to bend the steel feed line too much when you remove the filter, otherwise, the new filter will be a btch to get back in. And of course, you can use carb/choke cleaner for your motor.
That'll put your engine & trans & rear axle in tune, and it'll be a much better "baseline" to start improving on. If your engine's not running at it's best, why put aftermarket parts on it?
Old Feb 15, 2002 | 06:56 PM
KED85's Avatar
IN YOUR CASE
Like the car?
get it Cheap?
here's what ya do.
GET A V-8!
Easy to install, no computers, NO electronics, add your tranny that you get the wrecked V-8 drive train from.
One thing.
MAKE SURE, due to YOUR STATE smog laws, you can swap from a V-6 to (83 & above) V-8 without any problems.
Unless that engine is in primo shape to even work on, dump it and get a V-8 swap over.
Enjoy the project!!
PS GM sells this kit, but uses a V8 car to start with. #10185077
Old Feb 15, 2002 | 09:27 PM
JMBoriss's Avatar
Hey KED85,
I have an 84 SE. I also bought a pontiac 326 off a good friend. I already know about this motor, but what's your opinion? It's complete with the tranny and still running.
Take care,
Jon
Old Feb 16, 2002 | 10:58 AM
KED85's Avatar
Sell the 326 to a Pontiac resto freak.
It'll be better for both in the long run!
Make it easy for yourself and get a Chevy 350 & 700R4 Tranny.
Do it right and solid and have fun!
You only win in the end, but same suggestion, make sure you can smog it legal.
Old Feb 16, 2002 | 11:11 AM
fatass's Avatar
Car: 1986 Sport Coupe
Engine: 2.8l V6
Transmission: 3 speed auto
i found a used 350 tpi with computer for $850, and a used 305 tpi for $750, i might get either one, most likely the 350.
okfoz
Jul 1, 2024 01:40 PM
I-77 Camaro
Apr 4, 2015 02:25 PM
okfoz
FAQ Board
Oct 30, 2011 01:57 PM
okfoz
Jul 21, 2010 12:03 PM
