Doesn't concern 3rd Gen FBody But Help me!
Old Feb 15, 2002 | 09:48 PM
85CamaroRulz's Avatar
My dad has a 90 Mercury Topaz, 2.3 Liter 4 cylinder. I have a Camaro thats why I am at this site. He isn't getting any fire. The coil's good cuz we did a coil test. Why isn't it getting any fire? The battery isn't dead
Old Feb 16, 2002 | 02:32 PM
Camaro_hunter_d's Avatar
Is there spark from the plugs? Bad coil-dristib wire
Old Feb 16, 2002 | 07:35 PM
There is no fire from anywhere, The coil and the distributor are new and there is no spark.
Old Feb 16, 2002 | 10:14 PM
Sorry i read it wrong. My bad. Do you have current going into the ignition modulator?. If so is there any coming out? If not then theres your prob. The modulator will be in the same place as the one in the third gen, the distrib. Should be a semi "C" shapped thing with prongs. Test the prongs for current. 9 times outta 10 its the Ignition modulator that has gone bad if you get no spark, when just 10 minutes ago it was running.
Old Feb 16, 2002 | 10:44 PM
Yea he got up to go to work and he said while he was driving it just shut off and wouldn't start back up
Old Feb 17, 2002 | 12:38 AM
KED85's Avatar
From what I've heard, Fords are famous for bad ignition modulars, too.
It's an external one, right?
Old Feb 17, 2002 | 11:51 AM
DOH not reading again... fords are external..... At least most of them are...
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
