2.8L & 3.1L computers?...
Old Feb 17, 2002 | 11:45 AM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
are they the same? the reason i ask is bacause a guy i know has a performance chip for the 3.1L & i was thinking it might work with my 2.8.
Old Feb 17, 2002 | 04:45 PM
KED85's Avatar
IT MAY FIT
But doubt it'll be effective.
Doesn't 2.8 & 3.1 use a diff air inlet electronic set up?
Old Feb 17, 2002 | 06:16 PM
86Chicken's Avatar
It will not work because the 2.8s use a MAF type air sensor while the 3.1s use a MAP sensor. These are fundamentally different systems and are not interchangeable.
Dale
Old Feb 17, 2002 | 08:53 PM
ok i didn't think it would work anyway, thanks for the info
Old Feb 19, 2002 | 02:12 PM
89camaroRSV6's Avatar
ur 89 camaro same as mine is a 7302,
and the 91+ has a 7730 computer.,...
it wont work..
Old Feb 19, 2002 | 02:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
could it be the same computer, different prom chip?
Old Feb 19, 2002 | 02:37 PM
86Chicken's Avatar
No, the wiring to the computer is actually different as is the meaning of the signals read from the sensors. The chip might actually fit in the slot but it will not work. For a better explanation (that is over my head), search the DIY PROM forum.
Dale
Old Feb 19, 2002 | 02:40 PM
no project85,
me and another guy on the board (camaro_hunter_d)
who has a 92 RS have been tryin a lot on the PROM issue...
firstly 89 is MAF and 92 is speed density
secondly for v6,s the computer Number 89 - 7302 / 7302A whereas teh v8's used the 165 ECM
and the 92 both v6 and v8 used 7730ECM with just one byte sayin 6 cyl or 8 cyl in teh PROM (so comp same chip different)
unfortunately our car has no commonness to any other comp in the Fbody series
but fortunately (if u are famalier with the ECMs)
the 89 computer has both the 160baud connector and 8192 baud connector... in the 92 the 160 baud was taken off...
and the 92 computer uses a different kind of chip holder altogether (although the same chip) (the 92 also has a bigger space (ROM))
the 92 chip looks a whole lot different than teh 89
in the photo below
the 89 chip is the one in the top (black one)
(which i ahve in my car)
and the 92 resembles the one in the middle (the white one)
Old Feb 19, 2002 | 02:43 PM
and 86chicken not only are the wiring harness different the sensors are also differnet....
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
bplessy
Sep 30, 2015 12:14 PM
