Fyi
Old Mar 16, 2002 | 12:15 AM
RPS's Avatar
RPS
Fyi
FACT:
a speed limiter on my 92 camaro RS 3.1 5 speed is set to around 115-116mph... it dosent cut the engine off... well tonight the road was clear, so i was gonna see what it topped out at, when i hit 116 mph the computer made engine decrease rpms (as if i had let off the accelerator), it slowed down till it was about 85ish mph, then i could resume accel... well i was happy to find that my car will go much faster than 116 if i remove the speed limiter, i think it would hit 125 at 4900rpms in 5th
i was talking to my dad about his 87 camaro, and he had an automatic with a 3.77 posi rear. he said he used to do 2500rpms at 60 mph... i do the close to the same with my 5 speed manual with 3.42 mines 3000rpm at 60mph
all you ram air people, i bet there is allot to gain especialy if you are going 70mph... it would be a big difference. you have a decent setup like the dual snorkel and sheet metal,
Old Mar 16, 2002 | 12:03 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Just curious, but what gear are you in when doing 3000 rpms at 60mph? As far as I know I have the original gearing,( whatever that is) and at 3000 I'm at 100mph. The slowest I can drive in 4th (auto) is 45mph at about 1300 rpms. Once I change the timing chain, rebuild entire ignition system, fix exhaust etc, etc, I'll run it up to 120mph and see what rpms I'm at.
Old Mar 16, 2002 | 01:03 PM
RPS's Avatar
RPS
4th gear... i posted this mainly on the speedlimiter info... cuz i remember reading that it was set to 110, some said they went 119 without hitting the speed limiter... i had allot of rpm left over when i was going 110ish... i remember reading that the speed limiter would kill the engine and make you drift to a slower speed.
i dont know , mabie i misunderstood what they meant by it, but now i personaly know...
first time i hit the limiter, i was like ohh **** i breoke my car! (engine stops accelerating and slows down) then i realize it was a limiter, i tried it again, with same results...
so anyway, i want to know what exactle will bypass the speed limiter? i somehow thought the ECM chip would do it , but obviously my jet chip didnt do it...
Old Mar 16, 2002 | 01:05 PM
RPS's Avatar
RPS
for me 3rd gear is 40mph at 3000rpm. 60mph is4th gear at 3000rpm, 5th gear 3000rpm is at 75mph
Old Mar 16, 2002 | 02:21 PM
Camaro_hunter_d's Avatar
I know 70-75 in my 5 speed is 3K. And yes I have a $hit load of RPM's left wheh I hit my limiter at 112ish. 60 is 2500.
Old Mar 16, 2002 | 04:54 PM
Xenodrgn's Avatar
My car likes to cry when it hits 95 MPH... now that they upped the speed limit on the Parkway.. it's anything goes when it's not stopped up with traffic... this civic, eclipse and something else and me were all cruisin at about 80-90 Last Sunday... it was actually cool as hell... I know I hit 95-100 at some points... my car just kinda say "*** help me.. I'm falling apart..."
i'll never do that again without an Al driveshaft... those vibes from my current steel one don't feel too good....
Old Mar 17, 2002 | 05:15 PM
Engine: 3.4
I never really thought about the driveshaft. What do you mean by "Al" driveshaft anyway. Over here I'll be cruising at about 100 and just never put any thought into that what with all the other problems I've got (I'm a hypercondriack, hypocondriack, whatever), so to me there's alway something wrong with my car.
Old Mar 17, 2002 | 06:11 PM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
5th gear at 3000rpms for me is 90mph w/ 3.42's
Old Mar 17, 2002 | 07:59 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
that sounds correct
cuz i remember when i checked my RPMs on the scan tool at school, i said to myself thats where 70 MPH should be at
i need to go outside tommorow after work and reset my tach so it is correct
Old Mar 17, 2002 | 08:00 PM
sounds like your shaft came out of balance
the counter-weights probably fell off
could be bad u-joints too
Old Mar 18, 2002 | 11:18 AM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
coolrimsatleast, and AL driveshaft stands for aluminum driveshaft. I agree with 1991tealRSt-topGuy, it either the weights, or the u-joints.
Old Mar 18, 2002 | 11:54 AM
Ragnarok_Tyr's Avatar
It's true there is plenty of room left on the tach in 4th gear, but if you remove the limiter, your top speed won't increase by a whole lot. When the limiter is defeated, your car's top speed becomes drag-limited. The ablility of your engine to overcome the air resistance of your car becomes the determining factor. Since drag is a square function (as in the frontal area of the vehicle), to double your top speed, you must QUADRUPLE your engine's output. It helps that F-bodies are inherently slippery by design. The governor effect, by the way, is acheived by cutting off fuel to the injectors sequentially. It does slow you down quite a bit, so removing the limiter can help in that repect, because you wont slow down drastically and have to build up that speed that you lost again.
formula_novice
Sep 5, 2015 03:58 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
chubsworth
Aug 26, 2015 02:34 AM
R3500
Aug 24, 2015 09:05 AM
WECoyote
Mid-West Region
18
May 13, 2002 08:18 PM
