a non V6 question
Old Mar 18, 2002 | 08:23 PM
Camaro_hunter_d's Avatar
a non V6 question
I am planning on taking my V6 off the road(as you all already now) HOWEVER I am also converting my 305TBI to carb. I already know I need a 'verter lock up switch, and distrib. The obvious carb and intake. I plan on doing this with my 1200 in tax returns!
I am planning on having a fuel block, with return line/pressure regulator. Question is what PSI should I run it at? I am thinking 9 PSI...
Old Mar 19, 2002 | 05:16 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
carb is the way to go man!!!!!!
TBI sucks monkey pud
i have a edelbrock 600 performer on my 87 Z28 305
thats what i reccomend
and an edelbrock performer intake....................
why is the V6 comming off the road?
Old Mar 19, 2002 | 07:25 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
go for 5-7 psi, 9 max "for spirited street driving"
the 6 is coming off the road for fit & finish for the headers :hail:
Old Mar 19, 2002 | 10:40 AM
KED85's Avatar
Yeah, 5-6 I hear very very often is the max.
Get yourself a fuel pressure regulator.
Cagle makes one.
Simple in line dial set up.
I "hear" tbi fuel pressure is not as strong as the v6 one, too.
Old Mar 19, 2002 | 11:21 AM
Hmm turbo install.. header install.. Y pipe install.. and a few other things like a full front suspension rebuild.
Yeah I don't know what I was thinking with 9.. I'll go around 7.
And yes the TBI FP is 14PSI.
And I do plan on getting a fuel block w/ regulator and return line.
I chose the 625 electric choke I forget the brand, only 199, and a torquer(spelling I know) eldelbrook intake for some performance. I also chose a Accel distrib. 100 bucks I think?.. so In all about 500... Not bad for better performance and 40-60 ponies I have been told.
Old Mar 19, 2002 | 12:55 PM
Engine: 5.7 / 7.4
625 electric, sounds like a carter carb.
Old Mar 19, 2002 | 03:32 PM
Yeah it is... I looked it up again. I was thinking Demon, but I need a few more parts and rebuild before that I go that far...
Old Mar 20, 2002 | 07:38 AM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
C-Hunter
Why not go MPFI? it can be better than both carb and tbi when set up right. I know that is the only thing that make my 2.8 what it is.
Old Mar 20, 2002 | 08:26 AM
Engine: 5.7 / 7.4
you can make more power, in this case, with the carb conversion when set up right. tbi is just the bastard child of combining a 2bb carb & a "fuel injector". Plus it's a whole lot cheapeer & easier than going to the MFI setup.
Old Mar 20, 2002 | 10:53 AM
Originally posted by 86bird_28v6_5spd_ramair
C-Hunter
ok $500 to convert to carb, or over $1200 for MPFI... guess why...
MPFI costs WAY more and some things you can dial in a carb and it will be just as powerful as a MPFI. Nedless to say all the damn sensors and computer (rap. With carb I can thow a bunch of stuff on before having the change jets, its very forgiving. MPFI is alot ore finiky. Though yes it will eventually get the MPFI casue I would actually like to punch the 305 to 355 and put a turbo onto that!... but thats a long way down the road.
And PS I got the turbo today off ebay. damn thing weighs a ton, but theres a lot of stuff I can take off of it so I am...
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
