Engine Idles bad after 2030 Camshaft install
Old Mar 25, 2002 | 12:44 PM
89camaroRSV6's Avatar
I installed the 2030 camshaft...
and now the engine idles real bad even after 200 miles..
apart from teh cam i replaced teh PCV valve...
i need to know 2 things
1. i connected the PCV valve to a point in teh THrottle body and also to a point in the EVAP canister (using vacuum hoses) since my origianl plastic hose broke...is that right way to do it...
2. I get the SES light and when i connect and find error codes i get error 22 = TPS sticky/ BAd TPS
whats wrong with my car now...
does the 2030 crane cam have a very bad lopey idle
it dies if i put it in drive and not reva little or Throttle position has to be adjusted so much that Torque converter is gonna be messed up since engine revs in idle and DRive is 1000+ RPM
has engine Advance got something to do with this
Thanx a lot in advance guys
Old Mar 25, 2002 | 01:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
was it timed right after the install? did you also replace the timimng set?
Old Mar 25, 2002 | 03:01 PM
yeah i got a new timing chain set from dynagear
it was timed right ....both on the cam as well as the distributor..
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
