MSD 6a
Old Mar 31, 2002 | 08:27 PM
92Blue3.1's Avatar
MSD 6a
is it worth buying? if i were to get it i would get an msd coil too.but im not totally sure about it. if any of u guys have it can ya tell me if ya noticed at differance in milage and power. thanks
Old Mar 31, 2002 | 10:20 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I'm going to get 2 of those, 1 for the bonneville, & 1 for the bird. when the turbo is ready, I will get the BTM & add it to it. I don't see any reason to get the 6AL for an auto, the 6A should be fine, & it's cheaper too
Old Apr 1, 2002 | 01:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have the 6AL, just in case. Plus, it doesn't look like you can add a rev limiter to the 6A box at all. And eventually, for racing, I plan to get the MSD 2-step RPM box for it (1 stage for lining up at the tree, 2nd stage for running down the track).
I didn't notice much of a power increase, except /maybe/ a bit at high RPM's. I never keep track of gas mileage, so I can't help ya there. But I did notice the car takes an extra fraction of a second to start. It used to start up with a 1/2 second blip of the key, now it takes almost a full second.
The only reason I bought it (well, my girlfriend bought it for me as a gift!) was because I'm almost out of mods to the car. I'd suggest buying a high voltage coil first, and getting the MSD box when you run out of things to do on the V6. You can buy a regular MSD coil (2 wire), and that'll make it easier to hook up to an MSD box later. Yes, our 4-pin coil wiring harness can be modified to connect into a 2-terminal coil. But, take care of the common stuff first...
I run a MSD 6AL, with a Blaster SS coil, rebuilt distrib (stock parts, I want to do the Holley module one day), MSD 8.5mm wires, and Splitfires (which I'll be going back to AC/Delco's; the MSD seems to eat the Splitfires, damn.)
Old Apr 1, 2002 | 02:43 PM
Engine: 5.7 / 7.4
TomP, try the rapid fires & let us know how you like them.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
