Distributor coil....
Old Apr 2, 2002 | 03:18 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
How do you get off your distributor coil? I have been working at this for a while and it looks like it's connected at two bolts. These two bolts hold the bracket which holds the coil. Is there any easy way or any tips any of you guys can give me? Please help!!!
Old Apr 2, 2002 | 05:41 PM
KED85's Avatar
You're doing it right.
USe a DEEP Socket.
I think 10mm?
or 8mm
Old Apr 2, 2002 | 05:46 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
What do you mean by deep socket? Also, what does the egr look like? Is it that ufo thing or the thing with a bunch of electrical connections in it, ( closer to the coil) ? Do I need to remove either? Thank you ked85! Eric
Old Apr 2, 2002 | 07:08 PM
WaynesRS's Avatar
The egr thing , is the thing that looks like a UFO .
Old Apr 3, 2002 | 06:52 AM
KED85's Avatar
sorry Kinda screwed up.
You're making me recall when I rebuilt/swapped engines over a year ago.
Two bolts.
15mm
Bolted to exhaust manifold area.
Need an extension & short socket.
I recalled needing deep 8mm socket for some valve cover work.
Analogy
Sockets
Fingernail=socket
Deep socket= Fingernail to knuckle.
Make sense?
To remove the coil, drill out the rivets holding it into bracket.
GO get new drill bit, make it easier.
Many of us relocate it (coil).
Wish I had rest of my digi camera stuff.
I'd send ya pic.
Old Apr 3, 2002 | 11:48 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Are you replacing the coil? I got the Blaster GM coil and took the old one out using a tiny screwdriver and a chisel to spread the metal and bust the rivets. The new one came with nuts+bolts and the small brackets also.
Old Apr 3, 2002 | 02:06 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
Yeah, I am replacing it. Do you think I should just bust that dumb bracket? Sounds good to me, my new coil came with a bracket with nuts and bolts too! Thank you! Eric
Old Apr 3, 2002 | 04:00 PM
KED85's Avatar
Hold on there pardner!
Meaning, if ya destroy the bracket, you MAY NOT be able to reattach the coil, there.
Better decide where it goes, then "destroy the coil".
Me,
I decided my coil would be else where.
Then hooked up coil, got car running, removed/hacked offending bracket.
IN THAT ORDER, just in case.
Destroy/modify/rebuild your bracket outta the car.
Old Apr 3, 2002 | 04:12 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
So first, take off the two 15 mm bolts, take out the bracket, tinker with it and make sure it fits, then put it back in right?
Old Apr 4, 2002 | 05:57 AM
Engine: 3.4
When I busted the rivets, the brackets bend easily so I pushed the coil over sideways and chiseled the bottom 2 rivets. The coil wasn't damaged at all and the original brackets can be rebent, but the new one comes with the brackets, nuts and bolts anyway.
Hardest part was getting those tiny nuts started on the bottom half.
Old Apr 4, 2002 | 10:10 AM
KED85's Avatar
Open the hood & give it a look-see.
Decide which is best for YOU!!!!
It could be a 13mm, too!
Just get a BIGGER TOOL CHEST.
You are making this a difficult mission.
It is not.
Honest. Look what ya got, remove all offending objects, label if necessary, get to work!!!
Ya got a 1/2 hour to go, the car's owner is waiting in the lobby now!
It's Friday night and THE LARGEST CHRYSLER CAR SHOW (W of Mississippi) IS HAPPENING THIS WEEKEND!
Woodley Park, San Fernando Valley/Van Nuys Area.
FREE!! FREE FREE!!!
IMAGINE a ROW of 8-10 CHRYSLER SUPERBIRDS.
Then they ignite.
I've lost part of my hearing by listening to Chrysler Hemi's LIGHT UP, then Idle.
IT's better then sex.
One can do it on command.
Saturday night is the ILLEGAL ACTIVITIES at Cruiser Car Wash in Northridge.
Imagine the Northridge Earthquake (7.2!), idling in a parking lot.
www.cpwclub.com
Please attend.
My neighbor has
1970 Challenger RT/SE 440-6-Pak, Ram Air hood
1970 Cuda Lime Green 340, Hockey Stick Paint strip on side.
JUST GOT
1969 Challenger, Former SUPER STOCK drag racer (as my 1967 RS/SS Camaro 350 4-speed Convertible is) 440 6-Pak. Has magazine article about it!
Wife drives a 1999 Firebird T-Top
Daily Driver-35th Anniversay Corvette!
I like my neighborhood!
Old Apr 4, 2002 | 01:45 PM
Xenodrgn's Avatar
It's time consuming, but easy... open ended wrench and a small socket... unbolt the coil (there are 4 bolts, not 2... the bottom two are the hard ones...) then installation is the reverse of removal...
I noticed a smoother idle and a little better top end... thats it... I have the GM Blaster coil...
Old Apr 4, 2002 | 06:01 PM
elevario's Avatar
Car: 1992 RS
Engine: 3.1L V6
4 bolts?! Where are the other two?
Old Apr 4, 2002 | 10:08 PM
KED85's Avatar
Two bolts bracket & 4 rivets for the coil attachment
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
