BMW Rims on camaro
Old Apr 15, 2006 | 01:58 PM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
BMW Rims on camaro
Finally got to try my BMW rims on my camaro,, they are 18x10 rears and 18x8.5 fronts. Artec
Attached Thumbnails BMW Rims on camaro-bc2.jpg   BMW Rims on camaro-bc3.jpg   BMW Rims on camaro-bc5.jpg
Old Apr 15, 2006 | 02:07 PM
fenton06's Avatar
those look really good! Did you ahve to use any spacers or did they just bolt on?
Old Apr 15, 2006 | 03:53 PM
vortech35091RS's Avatar
Car: 1991 camaro RS
Engine: 350,vortech heads,zz4 cam,3:73 posi trac,edelbrock carb,wiend stealth intake,raven mufflers,hooker supercomp shorty headers and y-pipe.
Transmission: th700r4
Love the new look!
Old Apr 15, 2006 | 04:33 PM
Stevo's Avatar
Car: Pair of 92 Z28s
wow those fit pretty nice actually...also btw i meant to thank you for the springs write up, i lowered my car how you said and all went well. Thanks!
Old Apr 16, 2006 | 03:30 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
i love those wheels on our cars. what are the details on em? as far as make and model?
Old Apr 16, 2006 | 06:26 AM
proxemics's Avatar
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
they look nice
Old Apr 16, 2006 | 07:28 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
More Info
These wheels are straight off my 7 series BMW, they are ARTEC "ms3" here is their link ARTEC GmbH As I mention above the front are 8x8.5 and the rears are 8x10, Not excatly sure but I believe the BS is 6". The rears are direct bolt on and I did not have any clearence problems, The fronts have to be use with a spacer otherwise it won't clear our center bore which stick out to much. The front spacer I'm using are 1 1/4". I've got some 3/4" spacer that I think would look much better. This way it won't stick out as much. Also you may have notice the tires. On the BMW they call for a front 50 and rear 45, on the camaro they should be at least 45 fronts and 40 rears,, could also go 40 front and 35 FAT rears. The rims run about 250 give or take, at least you don't see many 3gen with these on.. To bad they have to go back on my BMW.....
Attached Thumbnails BMW Rims on camaro-bc6.jpg   BMW Rims on camaro-bildholen3.jpg
Old Apr 16, 2006 | 07:58 AM
soultron's Avatar
Car: 87 trans am
Axle/Gears: 3.42 SLP rear
That is very good looking.
Old Apr 16, 2006 | 10:59 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Are you driving this sucker around in Germany?
Imagine the looks there...
Old Jul 28, 2007 | 02:59 PM
Gottork1967's Avatar
Car: 83 Firebird
Transmission: 2004r
Axle/Gears: 10 bolt posi 3.08
Re: BMW Rims on camaro
Did you buy it over there or have the Camaro shipped in?
Nice look..
Old Jul 29, 2007 | 01:40 PM
ling427ttvette's Avatar
Car: 1983 Camaro Z28/1999 Cavalier
Good thing they are going back on the BMW, your R-F tire is on backwards, as I am guessing your L-F is too...
They look sharp on there though.. I never knew they had the same bolt pattern.
Old Jul 29, 2007 | 02:14 PM
trackbird's Avatar
Car: 1991 Corvette
Engine: 353 cu in
Transmission: M6
Axle/Gears: 3.45
Off the top of my head, I thought the BMW wheels had a bolt pattern that was a few mm different from ours? If so, I'd worry about the wheels coming loose since they are only really tight against one edge of the lug nut. This is from memory though, but I thought I'd mention it.
Old Jul 29, 2007 | 03:44 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
nice!
concidentaly,I saw a BMW 7 series with 15X7 Z28 rims
Old Jul 29, 2007 | 03:52 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Nah, not a few... It's something like .65 millimeters smaller IIRC.
Old Feb 21, 2010 | 06:32 AM
esp68camaro's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700-r4
Axle/Gears: 3.73 posi
I want these wheels and cant read the wheel web site
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
antares57
Aug 6, 2015 07:47 AM
