rear wheel backspacing
Old Dec 22, 2006 | 08:18 PM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
i am going to purchase a set of wheels for my car.i am planning on running
255/40r17 front & 275/40r17 rear.can any one tell me what the back spacing would be for 17x9.5 rear.i think front would be stock.i am also putting a 10 bolt disc brake unit in i had totally rebuilt(will that change any off sets-car came stock w/9-bolt borg-warner disc brake unit)?
wheels are torque thrust 2's
thanks
chuck
Old Dec 23, 2006 | 09:14 AM
Souseless's Avatar
Car: 89 WS6
Axle/Gears: 10 bolt T2R w/ 3:23
Since you are changing the rear axle and no one could know what length the new one is, no one can answer your question.
Old Dec 24, 2006 | 06:30 PM
Car: 91 Z28
Engine: 383-Carb
9.5x17" wheel backspacing
hello!
thanks for replying so quickly.
perhaps i was confusing in my description.the axle i am replacing the borg-warner(gm performance option)w/is a stock gm 10 bolt disc brake unit.by the
way both are disc brake rear ends,i think they are the same lengths? so
i guess anyone w/a 82-92 camaro w/a 10-bolt disc brake rear axle would have the same backspacing if using a 9.5"X 17" wheel.by the way i'm planning on running 275/40/17.
thanks again
chuck
p.s.
could possibly be 5.5"
backspacing
Old Dec 25, 2006 | 09:39 PM
BOTTLEDZ28's Avatar
Transmission: A4
go with a 5.5"BS on a 9.5" wheel.
Old Dec 28, 2006 | 07:53 PM
Car: 91 Z28
Engine: 383-Carb
5.5 BS ON A 9.5 WHEEL
thanks for your help!
but was that 5.5 bs for a 3rd gen 10 bolt?
thanks
crazychuck
Old Dec 28, 2006 | 09:22 PM
CrazyHawaiian's Avatar
Car: too many ...
Here is a picture of 9.5" wide rear wheel with 5.5" backspacing on a stock GM 10 bolt (275 tire). You should be good with 5.5".
Old Dec 28, 2006 | 09:44 PM
ICNVNU's Avatar
Car: 87 GTA
Engine: L98 BASED 389 W/ MODIFIED LT1 NTAKE
Axle/Gears: 342
WOULDN'T HAPPEN TO KNOW THE CORRECT BACK SPACE FOR A 4TH GEN REAREND AND 11'S WOULD YA?
Old Dec 28, 2006 | 09:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
ya 7" I believe. look at this page for more info...
http://www.skulte.com/adapterfaq.html
there are different size 11" wheels out there and some have different backspacing numbers so be careful.
Old Dec 28, 2006 | 09:59 PM
ICNVNU's Avatar
Car: 87 GTA
Axle/Gears: 342
I WANT TO GO WITH AMERICAN RACING AR 200S RIMS AND WANT TO CRAM 11'S UNDER THE BACK AND STILL HAVE IT LOOK LIKE CRAZY HAWAIIAN'S CAR IS IT POSSIBLE OR DO I GO MINI TUB?
Old Dec 28, 2006 | 10:03 PM
BOTTLEDZ28's Avatar
Transmission: A4
you will not get that look with 11" wheels without modifying inner wheel well. There are members on this board that have 11" wheels. Do a search and see what they had to do. The wheels in my sig pic are 11" wide on a 4th gen rear and they stuck out just a bit to much for my liking.
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
The most I ever see is a 10 inch rim width, and that is rolling the fender well lips.
Old Dec 28, 2006 | 10:04 PM
ICNVNU's Avatar
Car: 87 GTA
Axle/Gears: 342
THE WHEELS ARE AVAILABLE FROM THEIR "CUSTOM SHOP" AND CAN BE ORDERED TO MY SPECS THANKS FOR THE REPLY IT GIVES ME A GOOD PLACE TO START
THATS WHAT IM WORRIED ABOUT IM NOT TRYING TO MAKE A PACO RIDE
Old Jan 24, 2008 | 02:38 PM
hardcoreZcar's Avatar
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Re: rear wheel backspacing
So to fit 275 40 18s on my 18x9 rims. I would need a 5 inch backspace? Should i go 5.5? Im ordering spacers for vette wheels. The tires will fit too right? Thanks guys.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
