Which drag radials
Old Apr 21, 2007 | 11:30 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Which drag radials
I need some kinda drag tires for the stock 16" Iroc wheels.I cant seem to get traction no matter what I do on my street tires.I`ve tried lowering air pressure and heating up the tires,stageing the rpm`s up and i just spin and spin.I`m looking at these three.M/T ET street radials 255/50/16 $167.99,BFGW G Force T/A drag radials 255/50/16 $154.99,hoosier 255/50/16 drag radial $185.99.Price wise of coarse I like the micky t`s.Are they as good as a more expensive tire?Also my trans and rear diff are old and susspect,I`m sure the added stress can finish them off right?I`m wanting to upgrade anyhow
Old Apr 22, 2007 | 12:45 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
Re: Which drag radials
i have the BF's on my car and i like the way the car hooks up with them. expect the rear to be the first to go if you get the car to hook up.
Old Apr 22, 2007 | 07:54 AM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
seeing how you are a auto car. if you dont have a stall then that has something to do with it atleast on strret tires. but to answer your question i have the M/T and i love them drop psi to 12-15 alittle heat goes a long way. try them out you wil love them. good luck Later Daniel
Old Apr 23, 2007 | 11:45 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
i am in the same boat as shady but i am replacing my worn out 277 gears with 370 and new LS. What is ya'lls opinion on my rear going out still? Do you think my rear will still be the first to take a crap on me? sorry to take over the post....
Old Apr 24, 2007 | 06:09 PM
chevyboy07 91's Avatar
i've had Nittos, BFG's and the M/T's...THE M/T'S ARE BY FAR SUPERIOR for traction....as far as wear....1.Nitto, 2. M/T(close 2nd) 3. BFG...distant 3rd
Old Apr 26, 2007 | 03:47 PM
Shagwell's Avatar
Car: projects.......
According to your profile you have a 9-bolt. If so, you have nothing to worry about, except finding the gear and posi. They're much tougher than the 10-bolts.
The Mickey's hook best for an auto car, but they're the least street friendly tire.
Old Apr 27, 2007 | 11:27 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
i use MT's with the VHT track bite and it HOOKS UP. Might want to invest in a good rear end because i belive those slicks destroyed my 2.77's. Also i dont know if it caused this problem also , but my rear shocks got tore up with them on.
A buddy of mine has the hoosiers on his nova and it hooks up a little better ,but not by much
i never tried the BFG's but i am willing to bet its also a great tire any of them should fix your traction problems
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
fasteddi
Exterior Parts for Sale
Sep 29, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
fasteddi
Sep 10, 2015 09:32 AM
