16x8 aftermarket rim (wheel sizes)
Old Oct 14, 2007 | 07:56 PM
Knight_roider's Avatar
hey i have 245, 50 series on my 16x8 - i was thinking about lowering the car and dropping to a lower series tire. do i risk any injury to the rim by dropping? i was warned that i may.
thanks for any help!
what's some of the most used 16x8 wheel sizes that are used?
Old Oct 14, 2007 | 08:02 PM
Re: 16x8 aftermarket rim (wheel sizes)
i'm not sure how to post pics... if someone could help me out with that i would
Old Oct 14, 2007 | 08:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there would be no interference with that tire and a lowered car, no reason to change, besides it would mess up your speedometer. The only rim damage issues i could see, is if you use a much narrower tire, and at that point you would be more susceptible to curb rash
Old Oct 14, 2007 | 08:57 PM
so what would work if i wanted to drop to a lower pro tire... could i drop to a 40 series?
Old Oct 14, 2007 | 09:16 PM
Stephen's Avatar
Car: 87 GTA
What kind of backspacing do you have? As it is, the stock 16 x 8s have less backspacing than the rears. Making the rears having a shallower dish.
Old Oct 14, 2007 | 10:34 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
How are the roads where you live? For sure, the more you lower the profile of your tires the more of a shock the wheels will have to endure as you ride over bumps and pot holes. Also, when lowering the vehicle keep in mind that the shocks will have less travel and therefore less dampening (read rougher ride). If you're going to do it (you'll love how the car looks afterward) spend the money on quality shocks (tokiko, Koni) to go with the lowering springs. You don't want to wind up with stress fractures in the chassis. Unless you are driving on silky smooth roads I would be cautious about going to less than a 45 profile. Jon
Old Oct 17, 2007 | 11:43 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Why do you want to lower the profile of the tire?
There is nothing to be gained by this...remember that if you drop the car and reduce the tire profile there will be the same size gap as there is now!
Also as 86TA stated, the speedo will be out as well. If the intention of dropping the caris to fill out the wheel well and reduce the gap then stay with a 50 series tire.
Old Oct 19, 2007 | 12:42 PM
Shagwell's Avatar
Car: projects.......
That I know of, there are no comparable width tires of a lower profile series. A 235/45/16 is only marginally shorter(roughly .2") but is also 10mm skinnier. 40 series or lower for 16" sizes usually max out at around a 215 width, thus would look/handle like garbage, as they would be too skinny for a 8" wide wheel.
You can lower these cars low enough so that they handle/ride like crap and bottom out on just about everything, all while maintaining a 50 series tire, so even if there were sizes available, I can't see a reason to run them.
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
