265 45 16 too wide to run up front?
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
hey guys im looking into the new kumho XS tire in a 265 45 r16 for autocross and some street driving under 3000 miles a year . is this too wide to fit on the front they have no 245 45 16 tires the only other option is 225 50 16 so should i go with 265s all around or 225s up front 265s in back? any input would be appreciated thx
Car: 1994 Trans Am
Re: 265 45 16 too wide to run up front?
I bet they would rub up front, but only at full turns, which you wouldn't be doing at high speeds anyway.
Btw, they are currently on sale at tirerack for like $170 as opposed to $190. I'm looking to get a set for my car as well, just because I like fatter tires. i have the worlds skinniest 245s on my car right now. Swear to god, they look like 215s. LOL!
Car: 87 GTA
The real questions are.....
Where will the 265 sidewall on a 16" end up, in the relation to the ball joint?
And what is the backspacing of your wheels? I have 275/40/17s with ZERO rub, but under 1/4" clearance between the tire sidewall & the ball joint. Safe, but I couldn't go any wider...With my 5" backspacing.
Car: 87 GTA
Heres my 275/40/17s......
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI
Transmission: T-5 Manual
Axle/Gears: 3.42 4th Gen
Aaron
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
For auto-X use, I would use a "Race-compound" tire. I used to use pirelli P-7's on the track and it was a mistake. Street tires tend to scrub and chunk when only used for auto-x. Thats just my experience, though.
Good luck!
Good luck!
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I run 265/45/16 kumho v710's on my car and it doesn't rub at all.
I like the tread design of the kumho's. They are reasonably priced too... They are my other choice for my 245/50/16 fronts.
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
I just got my new 2010 camaro yesterday, it comes with 275/40R20 dia =28.66 rear,and the front 245/45R20 dia =28.71 the rims are painted silver. But when i ordered the car i got theh upgrade to 21" wheels. Im going to try the 20" on the camaro instead of my 275/40R17 and 245/45R17 the dia of each is 25.6 3 inches taller just wondering if they will fit
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
I have a set of kuhmo ecsta 265/45/16 R compound that stick like glue for auto-x make me an offer cause they gotta go. I also have a set of hoosier a6 R compounds 245/45/16 on set of 4th gen salad shooter wheels I need to get I'd of also. $200 and u can have everything but u have to pick up
Car: 91 Z28
Engine: LB9
Transmission: auto
The 265/45/16's should fit without a problem. I'm assuming that you are using the stock wheels with stock backspacing though.
