traction help
Old Aug 18, 2009 | 02:27 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
traction help
hey guys. does anyone know how wide a tire/wheel combination i can put under my 84 Z28? has anyone used mini tubs? if so what all is involved in the instalation of mini tubs? i'd like to use a 10 inch rim and maybe a tire size 300 50 r15. thanks for any help
Old Aug 18, 2009 | 04:22 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: traction help
do a search for minitub. that topic has been talked about and done by many. you can actually run a 10" rim with the stock wheel wells. just takes some clearancing with a BFH. all of what you ask has been covered there on TGO. just use the search button.
btw, there the tire you want is a 295, not 300. if you are having serious traction problems, a drag radial or DOT slick may be what you need.
Old Aug 19, 2009 | 10:57 AM
Re: traction help
hey, thanks for your reply. so you're sayin i can "tuck-in" the 10" rim. with a big f-in hammer? the class i race in does not allow any kind of racing tire,. just a street radial...thanks again
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
