Wheel Spacers
Old Jul 20, 2009 | 09:23 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
Wheel Spacers
since skulte has stopping making wheel spacers.. whats the next good wheel spacer to buy? anybody know?
Old Jul 21, 2009 | 08:55 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: Wheel Spacers
I recently bought mine from this place:
http://www.motorsport-tech.com/
Made in the USA. Fair price, quality piece, a little slow, but I thought it was worth it.
Old Jul 21, 2009 | 11:13 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Wheel Spacers
I have never used them but at $140 a set that is a good deal I think I paid $115 for my Skulte adapters used. I am probably going to polish them so they will look new anyway I guess
Old Jul 22, 2009 | 06:47 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
what do i need one peice or two piece there kinda confusing?
uh wdf is our stud size?
Old Jul 22, 2009 | 06:52 PM
Stephen's Avatar
Car: 87 GTA
Re: Wheel Spacers
All your questions woulda been answered on TGO, had you done a "search:
Here is where you can get them & the answers you seek also.....
http://www.skulte.com/
BTW...No such thing as a 2-piece wheel spacer.
Old Jul 22, 2009 | 06:53 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
wow i need to know stud size and the and center bore..
Old Jul 22, 2009 | 06:56 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
ok so its M12x1.50 what about the center bore that motorsport is talking about and 2.25 is to big? i looking for 2 with 2.25 i think it would make my wheels stick out from the wheel well.. not what i want
Old Jul 23, 2009 | 07:19 AM
Car: 1986 Iroc
Engine: Afr 408
Re: Wheel Spacers
You don't need a two-piece. Just the one piece. I also chose to get a hubcentric ring machined in as well. I have a pic of the adapter I used in my thread about my Zr1's in the suspension and chassis section.
Yes, our stud thread size is 12mm x 1.50
The stock center bore is 70.3mm
What wheels are you going to be putting on? That will help you determine thickness.
Old Jul 23, 2009 | 09:35 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
oh i running c6 z06 wheels
tires are 295/35/18 back 255/40/17 front
was planning on running two inch spacers but if the 2.25 will work all around without my tires sticking out i could go with those but i have a feeling they will
Old Jul 24, 2009 | 09:24 AM
Car: 1986 Iroc
Engine: Afr 408
Re: Wheel Spacers
If you've measured for the 2 inch get the 2 inch adapters. The way I measured for the rears was I jacked the rear of the car up and put a board or something I could slide under the new wheel and tire. I manuvered it into the position I wanted it and took the measurement from the brake rotor to the inside of the wheel. Sort of crude, but it helped me.
Old Jul 24, 2009 | 07:24 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
hmm ok.. well people told me with stock rearend and such two inch adapters will work
Old Jul 26, 2009 | 04:09 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
how much would 2.25 stick out?
Old Jul 29, 2009 | 09:18 PM
Car: 83 Z28 Camaro
Re: Wheel Spacers
did 83 camaros come out with all around disc brakes stock by any chance?
Old Aug 11, 2009 | 07:01 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Re: Wheel Spacers
Hi guys,
I'm pretty much wrapping up business with Skulte Performance Designs, as I have less than zero free time left over from the day job. Anyways, We did offer custom 2 piece adapters to change the bolt pattern to a different number of studs. The first piece would bolt on to the hub, be machine hubcentric, and have a counterbore machined to center the second piece. Dowel pins were also pressed in to handle timing as well as shear loads. The second piece had the wheel side bolt pattern machined and pressed in studs, and was bolted together with staggered countersunk cap screws. I'm a big fan of KISS, but this was really the only way to change from a 7 lug to anything else (we have a set left over if any of you guys want to convert your 7 lug F150 & 250's to 8 lug). We also did bolt patterns to go from 6 to 8, 4 to 5, etc... There was a lot of machine work involved so they weren't cheap, but many times my customers would find great deals on used wheels that didn't match, so it would be worth it.
Also - I have a new pair of 2.25" adapters still in stock, along with some random other non-5x4.75" adapters and spacers I'd be willing to let go at half price, as well as some brake ducts (and will be parting out the Z28tt while moving to a Z06...). When I get a chance, I'll update the website. PM or email me if interested...
Andris
Old Aug 19, 2009 | 11:14 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Wheel Spacers
I am looking at buying this pair of Z06 Rims 17X9.5 with a 54mm offset. I am planning on putting a 245 40 17 on the fronts and 255 40 17 in the rear
They are actually the center wheels in the pic
http://www.tpis.com/index.php?module...C5+ZO-6+Wheels
What adapter size am I going to need to put on my 88 camaro. Will I need a 2 inch or 2.25 inch. And you said askulte, that you were letting these go at half price in the last post?
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
