will these make a difference in speedo reading
Old Sep 15, 2009 | 02:02 PM
katnic86camaro's Avatar
Car: 86 camaro,87 camaro,87 camaro rs
Engine: all 3 2.8 v6's
Transmission: 5 speed and 2 4 speed auto
i have an 87 Camaro RS. They came with 15 inch wheels correct?? now my question is can i put 14inch wheels on it if i change the hubs?? And will it be a problem with the speedo maybe being off a few miles cuz of the change to 14s??
Old Sep 15, 2009 | 02:16 PM
1988-305-tbi's Avatar
Re: will these make a difference in speedo reading
rim size does not effect the spedo, but why would you put 14" rims on? thats even smaller than the 15" rims already on there??????????
Old Sep 15, 2009 | 02:42 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
The problem you will probably run into is the brakes. The stock rims are usually the smallest rims to fit over the brakes.
As far as speedo problems, it not the rims size, but the tire size, height, either way tallers or shorter, there will be a difference.
Eric
Old Sep 15, 2009 | 07:22 PM
well due to my finances the tires that were on the RS are shot and i have an 86 thats headed to the scrap yard that has good tread but 14inch rims. So thats where im at, thanks for the help
Old Sep 15, 2009 | 07:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if the rims fir the 86, they will fit the rs. The only thing that would make the speedo change is if the tire height is different
Jorlain
Aug 24, 2022 05:11 PM
onefreakz
May 14, 2018 12:15 PM
Wade787b
Sep 29, 2015 01:15 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
beachrodder
Aug 7, 2015 04:27 PM
