why do my tires look flat but have proper PSI
Old Oct 17, 2009 | 06:48 PM
91R5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I have a set of BFG traction T/A's and the left side are less than a year old but the right side is who knows. Does the age of the tire affect how it sits even if they have proper PSI (30) the right sides look like they have a bulge at the bottom
Old Oct 17, 2009 | 07:08 PM
Deimos140's Avatar
Car: 91
Engine: 427 with dual stage fogger
Transmission: TH400 with 2.75 1st
Axle/Gears: 4.11 moser 35 splines
Re: why do my tires look flat but have proper PSI
put 32 to 35 in number one. BFG's have a soft sidewall number 2. Its normal as tires gain heat they gain psi and look less flat as they go down the road. Sometimes if you weak the sidewalls by running on them flat the tires will look low and have bumps (probably not in your case) 30 psi is too low though.
Old Oct 18, 2009 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The door placard for my IROC 16's calls for 30 pounds, which I run for the sake of comfort.
JamesC
Old Oct 18, 2009 | 07:43 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
you'll get better gas mileage with more psi, it might help on quick turns, it won't look as flat, and it's plenty safe up to like 50 psi.
may cause a bumpier ride, but i'd put em at 35 psi. can't hurt to try.
Old Oct 18, 2009 | 10:24 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Somewhat off topic but do those tires ride decent? Are they noisy? Looking for new tires to replace my Walmart specials that are driving me crazy.
Old Oct 18, 2009 | 07:49 PM
91R5's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
yeah they ride great and handle great. The car really whips around corners when its dry out. when its wet I try not to take corners to fast because I've felt the back end start to slide out on me before. They arent noisy or anything at highway speed. I was going off the door sticker to which says 30 psi...
Vintageracer
Jan 10, 2020 05:33 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
