Corvette rim questions
Old Nov 8, 2009 | 11:52 PM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
On these rims (link below) do i need spacers? adapters? and the bolt pattern is the same as a 89 formila right? also what tire size for the front i was thinkin 245/45R17 then what for the rear 18-10.5
Old Nov 9, 2009 | 08:04 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Re: Corvette rim questions
I see no link, but judging by the 18x10.5" rear you're talking about, i'll assume you're talking about running a Z06 rim. For the front, you can run a 275/40/17 and the rears run a 295/35/18. Those are the stock Z06 sizes. You'll need 2" spacers all the way around unless you're running a 4th gen rear. With the 4th gen, it's wider so the spacers aren't needed.
Old Nov 9, 2009 | 04:18 PM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
theres the link is sorry bout that. so what you are sayin is that i put a 4th gen rear on my car that i wouldnt need spacers for that rear? do i NEED them for the front? and if so why explain i dont understand thanks. i guess maybe clearnace issues
Old Nov 9, 2009 | 04:57 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
i got 18X10.5 with 2.25 inch spacers and i like they way they fit and i have 295-30-18 i going to get 315 next time i get tires for the rear
and for the front.. i have a 17X9.5 rim but i have the 2.25 inch spacer for the front as well and the tie rod ends are really really close to hitting the rim.. i actually had to grind on of them down so they wouldn't hit... so idk about a 2 inch spacer
Old Nov 9, 2009 | 07:19 PM
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
well can you send me some pics so i have an idea of how they set
Old Nov 9, 2009 | 07:43 PM
Stephen's Avatar
Car: 87 GTA
Which Vette wheel you have, will determine which spacer you need.
http://www.skulte.com/adapterfaq.html
Old Nov 11, 2009 | 07:43 AM
rce2win's Avatar
Car: 1988 IROC-Z
Yes, if you run a wider 4th gen rear, you can run the 10.5" Z06 size wheel w/out spacers. The fronts are still 9.5" wide and the offset is different from the stock wheels, so that's why the spacers are necessary. Once you get them, try bolting them up w/out them...you'll see instantly why you need them.
Frozer!!!
Jan 19, 2024 04:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
