255/50/16 on a 91 gta?
Car: 91 GTA
Axle/Gears: 3:73
I have the opportunity to pick up a set of 4 used firestone firehawks for $200 obo... 2 are like brand new and the other 2 are 50% tread left.
1. If these tires are in good condition would this be a good purchase?
2. what do these tires feel like on the road, as there not factory size (255 vs 245).
3. are these tires still in production?
I was thinking of using them on the rear of the car only and purchasing new 245/50/16 to use on the fronts.
I was really hoping to use the 50% on the fronts and newer on the back. Because $200 bucks is saving me having to buy new!
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: 255/50/16 on a 91 gta?
255/50-16 work on the rears with no problem. The fronts will rub the inner fender when turning sharpley.
Yes, 255's are still available.
Car: 87 GTA
I've run 255/16s, on stock wheels on the front before, got no rubbing, not even after lowering the car.
I have 275s up front, on my 17" wheels now. Lowered (just a tad
) and they don't rub either.
) and they don't rub either. Thread Starter
Car: 91 GTA
Axle/Gears: 3:73
thats good news!
im willing to take a chance and use 255 in all four corners.
I need tires and dont want to pay $900- $1100.
I have 275s up front, on my 17" wheels now. Lowered (just a tad ) and they don't rub either.
Car: 87 GTA
Car: `86 SS / `87 SS
His GTA would have a steering box with internal stops that helped keep the 16" wheel cars from rubbing. Your steering box, while a direct swap, probably has lesser or no stops.
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
My '88 WS6 (17,000 mile all original car including the factory Gatorback tires) & my '91WS6 had inner fender contact with the stock tires & wheels when backing up with the wheels turned. Not sure why your car does not touch.
For the original question, the 255's are minimally larger & will work fine.... just be careful backing up with the wheels turned sharply.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
