Wheel spacers
Old Feb 25, 2010 | 06:53 PM
sneezer's Avatar
Wheel spacers
Am considering going to 3inch wheel spacers keeping the original tire size and wheel size. Would appreciate if someone who has done this before could let me know how this worked out. Front and back wheel spacers i'm planning on. Good motoring...
Old Feb 25, 2010 | 06:55 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Wheel spacers
sounds like it would be perfect on a trolls car
Old Feb 25, 2010 | 07:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: Wheel spacers
what are you trying to achieve?
Old Feb 25, 2010 | 08:15 PM
sneezer's Avatar
Re: Wheel spacers
Was thinking for more stability. Wider stance. Reading some of the post on here regarding wheel spacers I'm beginning to wonder if thats such a good idea.
Old Feb 25, 2010 | 08:28 PM
Project-RS's Avatar
Re: Wheel spacers
wheel spacers are usuaaly done if putting vette wheels on because of there backspacing. 3 inch spacer would be illegal unless you have fender flares that cover the wheel (thats how it is in rhode island) plus im sure you would rub real bad on all 4 tires just from driving. 3 inch spacers on a 3rd gen rim is an EPIC FAIL
Old Feb 26, 2010 | 08:20 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Wheel spacers
there is a lot more to stability that just pushing the wheels out further.
i would leave them alone
Old Mar 4, 2010 | 08:28 PM
sneezer's Avatar
Re: Wheel spacers
Thanks for the reply. Being new to this I don't know all I should,that's where it is valuable to have a forum like this to get answers from those who know Thanks again, I thinl I'll stick to the stock wheels and tires.
Old Mar 4, 2010 | 08:31 PM
sneezer's Avatar
Re: Wheel spacers
Thanks for the info,this why this forum is so valuable for getting info from those that know,saved me from a lot of grief..
Old Mar 4, 2010 | 08:45 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: Wheel spacers
Why are they bad? I was gonna get a set for some 4th gen rims I have and I know nothing about this stuff...
Old Mar 4, 2010 | 10:45 PM
MarionCobretti's Avatar
Car: '91 Formula (semi-project)
Engine: 5.0 TPI
Axle/Gears: 3.42 Posi
Re: Wheel spacers
For fourth gen rims they're not bad (other than the fact that they're a pain to install and uninstall). They're actually needed if you're running fourth gen, Corvette, BMW or other such rims with incorrect offset/backspacing, to properly space the wheels. It seems like the OP wanted to install spacers "just because," though, to make wheels that otherwise fit stick out a little further.
Perhaps not as drastically as the "bowlegger" look that some low riders adopt (see attached), but I think that was the gist of it. That is the idea people were trying to dissuade him from.
Old Mar 10, 2010 | 08:52 PM
sneezer's Avatar
Re: Wheel spacers
I had asked on this board if wheel spacers on a 3rd gen would be ok. Most replies were negative. Ex: tire rub,state law may require flares to cover the tires, also the extra weight,axle stress and so on. I'm considering yet but not sure if I will attempt that. Best advice is to take seriously those who know from experience.
Old Mar 12, 2010 | 12:15 PM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: Wheel spacers
Installing wheel spacers simply to move the tire/wheel outward is a big no no. It puts great stress on bearings & axles. Besides it looks like $#!^. When correcting a wheel offset issue, it's perfectally acceptable. In this case your not moving the tires out any farther than the stock dimension, only the mounting point, so the stress (leverage point) doesn't change. Example, I have C5 vette wheels on my 3rd gen, which requires spacers to get the wheels/tires back to the origional location. I hope this helps, Dean
Old Mar 12, 2010 | 07:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Wheel spacers
im not convinced the spacers put a ridiculous amount of extra stress on the bearings. They bolt to the wheel, effectively making the hub on the wheel thicker, thats it. No massive extra load aside form the extra weight.
the issue is all the extra lug nuts. You have to properly torque the spacers lug nuts, they re-torque them regularly to be safe, if they come loose, you can shear studs and loose a wheel. Thats the problem with them. If you install them properly and torque they properly and keep after them, you will be fine.
the tires cannot be sticking out from the side of the car, its illegal in most if not all states.
Old Mar 12, 2010 | 09:21 PM
DeanJ's Avatar
Engine: LS6
Re: Wheel spacers
There will be no extra stress if the spacers do not move the wheels from the origional location. The OP wanted to use the spacers to move the wheels outward, that means added stress. Bad idea, because of a number of things that everyone stated. Dean
Old Mar 13, 2010 | 08:35 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Wheel spacers
what the OP wanted to do, move the wheels out 3", is a bad idea and will cause issues, but the use of spacers in general to properly fit 4th gen/vette rims for instance is fine
Old Mar 23, 2010 | 11:02 PM
rippinit91Z28's Avatar
Re: Wheel spacers
i recently bought 8.5 by 18 vette rims. what size spacer is needed? i was thinking 1 inch?
Old Mar 23, 2010 | 11:06 PM
Re: Wheel spacers
i recently bought 8.5 by 18 inch vette rims and dont kno what size spacers i need. i was thinking 1 inch?
Old Mar 24, 2010 | 07:04 PM
DeanJ's Avatar
Engine: LS6
Re: Wheel spacers
My C5 vette thin spoke wheels needed 2" spacers. They were 8.5 X 17, with 56 mm offset.
Old Mar 24, 2010 | 07:19 PM
Stephen's Avatar
Car: 87 GTA
Re: Wheel spacers
Until we know WHICH Vette wheels, it is a guessing game. 2" is pretty common to make a Vette wheel fit, but going thicker or thinner can be better.
Measure the backspacing & we can be more certain.
Personally? I say sell the Vette wheels & use that $ + what you were spend, on wheels that fit, without the extra weight of spacers, the extra 20 lug nuts AND the 20 extra lug studs.
Old May 7, 2014 | 08:59 AM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Re: Wheel spacers
How big are the tires that you run with your 17 x 8.5s? There is a set of C6 ZR1 near where I live for pretty cheap without tires. I was thinkin NEXEN N3000 ZR17 INCH TIRES 275/40R17. That shouldnt have to much rubbing should it? Give or take a little hamering possibly?
Old May 7, 2014 | 07:58 PM
DeanJ's Avatar
Engine: LS6
Re: Wheel spacers
The 17x8.5 wheels are on the front. The tire size is 245/45 17. The rears are 18x9.5 and the tires are 275/40 18 and they do not rub at all.
Old May 7, 2014 | 10:11 PM
Car: RS Camaro
Re: Wheel spacers
Crikey. How do I post a video link in here... ill show you what I'm sitting at right now when someone says how to post a video! But my tires are the 16in aluminium z28 wheels from a 91-92. So im running 245s federal Super Steels 595s on all corners. (I just put the whole name in there, idk what 595 stands for) And the video will show how close i am on both sides. The back tires will be fine, but front ones will definitely need some massaging. i'm assuming that the guy before me has put lowering springs in it since there are some warranty warning about lowered vehicles from Les Schwabs (tire place) that shouldn't affect it to much really? Just wheel height in general? And I attempted to put my mechanics teachers BBS's on (for S***s and giggles) just tried one on the drivers back tire, and I didnt get to set it down to the different stud spacing and offset of course, but they were 17 in BBS's with some nice good 235s. My point being. I wanna get the bang for my buck, and try and run the same size tire all around and wheel. I could get billet wheel spacers with the new wheels studs for the offset's for what ever wheel i really wanted, but it comes down to what are the best. The 98-02 SS wheels are gorgeous, but I also love the ZR1 reps. Suggestions. I'm just testing the water to find out for sure, This combo wont be fu-filled till probably near the end of this summer... Throw some information back at meh!!
Last edited by Mr.ChevyStroker; May 7, 2014 at 10:32 PM. Reason: Terrible grammar; My apologies!
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
