Tire rubbing on fender
Old Jul 8, 2010 | 11:58 AM
viper23's Avatar
Car: 92 Camaro rs
Engine: Edelbrock 350
Transmission: TH 350
Axle/Gears: 373
I have a 92rs camaro which has P295/50R15s on it. Whenever I turn sharp or have people inside it rubs on the top of the fender. I wannna make these fit some how or just stop them from rubbing. What could I do harder springs maybe idk you tell me?
Old Jul 8, 2010 | 12:08 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Tire rubbing on fender
Stop making sharp turns and taking passengers. Problem solved.
Old Jul 8, 2010 | 05:44 PM
HOBBS's Avatar
Car: 1982 Z28 (work in progress)
Engine: 305 cu -H-
Transmission: Metric 200 (blah)
Axle/Gears: 3.23's
you could roll the fender lips up, or different offset wheel, or have a wheel repair place machine the mounting surface of the wheel to change the offset.
Old Jul 10, 2010 | 07:06 PM
Gabaloo's Avatar
i have 245/40z on my 91 and it rubs only when im turning right. i dont see any of the guards or anything loose or hanging, but thats sure what it sounds like.
Old Jul 10, 2010 | 08:14 PM
Stephen's Avatar
Car: 87 GTA
We'll need to know your wheels to help you better. Without knowing the backspacing of your wheels, it'll just be a guessing game.
Sounds like your rear end is off set, if it only rubs on 1 side. Check the bushings in your Panhard Bar, If they are good, get you an adjustable Panhard Bar. My stock bar, on my GTA with stock springs at stock ride height, with good bushings & stock wheels & tires, was offset to the drivers side.
Old Jul 10, 2010 | 09:32 PM
Gabaloo's Avatar
i should have been more specific, sorry. only my front right tire rubs when i turn right. or briefly catches something
Old Jul 10, 2010 | 10:01 PM
Stephen's Avatar
Car: 87 GTA
Since the OP asked about 295s, which are very unlikely to be run up front....I assumed you meant the rear too.
Just a bit of advice.....
I recommend starting your own thread to ask things, instead of just asking your question (which turns out to be pretty unrelated) in other peoples threads.
Old Jul 10, 2010 | 10:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I get that rubbin in the front with 225/60/15s but only when backing up and turning real sharp, sounds like it catching on the mud flap or inner fender, I can hear the plastic make a racket. Though its all bolted down tight.
Old Aug 1, 2010 | 10:52 PM
texascat2's Avatar
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Hey Stephen, who built your BW 9 bolt? I have a real problem finding parts except for 9bolt.com.
Thanks!
Old Aug 1, 2010 | 10:55 PM
Stephen's Avatar
Car: 87 GTA
Thanks!
Who? AFAIK, the Pontiac Factory Assembly line at GM back in 1987. And yes....My posi still work perfect after 23yrs.
Old Aug 1, 2010 | 11:11 PM
texascat2's Avatar
Ha! I thought I would get a hand slap for changing the thread. My posi still work perfect too after 21 years. Why is it no one carries parts for them in the states?
Old Aug 1, 2010 | 11:26 PM
griemar's Avatar
Car: 86' Camaro
Engine: 2.8L V6
THREAD JACKER! *Slaps you on the hand* Next time I'll send a nun and a ruler, LOL.
Old Aug 1, 2010 | 11:30 PM
texascat2's Avatar
And the LATE NIGHT warriors strike again! Ha!
No.......not the nun Wrong end!
morrow
Jan 13, 2024 12:29 PM
87v6Bird
Jul 1, 2018 04:12 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
