2010 camaro wheels/tires
Old Aug 4, 2010 | 02:12 PM
WILL85IROC's Avatar
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
this guy i work bought a 2010 camaro a while back then upgraded to a sportier pkg. he want s to sell his old wheels and tire and that came with car.. will they fit my 1985 iroc? if so, im gonna buy em' ... thnx
Bolt Pattern: 5x120
Offset Range: 35 to 45
Wheel Size Range: 20x8.0 to 22x9.5
OEM Tire Size (Front): 245/45-20 (245x729 mm)
OEM Tire Size (Rear): 275/40-20 (275x728 mm)
Old Aug 4, 2010 | 02:36 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Re: 2010 camaro wheels/tires
https://www.thirdgen.org/forums/whee...heels-fit.html
Theres more threads around about the subject, look around.
Old Aug 4, 2010 | 02:41 PM
Stephen's Avatar
Car: 87 GTA
Fit? With the right spacers sure. Would it look good? 90% of the people here will tell you no, including me.
17" looks good. Some 18" look good. Anything bigger looks out of proportion on a 3rd gen.
There is the mention the ride height increase you'll get. Your talking about a tire that is 3" taller overall. That means you'll be sitting 1.5" higher.
And then there is the issue of tire clearance to the body. 3rd gens do not have 1.5" of clearance over the tires. So you'll hafta put a lift kit on the car.
And then....What about turning? Your gonna hafta be very careful & probably have to fabricate new stops for the spindle.
You can try it, but you'll be in for a world of trouble doing it & making it work.....
Old Jul 12, 2011 | 05:44 AM
tekkitan's Avatar
Car: 87 IROC-Z
Don't believe everything you read. Lots of people are surprised on how well they look on third gens.
https://www.thirdgen.org/forums/whee...hlight=5th+gen
You don't need a lift kit either
Old Jul 12, 2011 | 06:54 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
The stock tires on a 5th gen are a 28" tall tire. The stock tire height for a 3rd gen is 25.65". Ideally you'd want to get different tires.
Old Jul 12, 2011 | 07:12 PM
tekkitan's Avatar
Car: 87 IROC-Z
yep. stock front for 5th gen i believe is 245/45/20. be better off getting 245/35/20 or 255/35/20
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
