Are 295's alright to run on a GTA rim?
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
I see some people running 295/50/16's are these ok to do? or is it very risky? what is a good brand of tire to use and does it require any modding to make them fit? my 245/50/16 just arent cutting it.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Are 295's alright to run on a GTA rim?
They'll fit but they're 2" too tall and will look like old bicycle baloon tires, imo.
http://www.tirerack.com/tires/tires....=yes&tab=Specs
Car: 87 GTA
Great fit. Look good, Been there, done it myself. 100% boil-on, no fenderwell mods needed.
Guest
Posts: n/a
Car: 92 T/A 'vert
On Probation
Engine: several
Transmission: none
Axle/Gears: none
doesn't matter what GM gave us, what matters is looks. 27.0" looks best, 25.7 looks too small.
If you want ultimate grip, then looks don't matter, fit some 17x9.5s with Hoosier R-S3 255/40R17, which have a full 10" of tread width, and are far stickier than Radial T/A tires.
