Anybody else running these sizes?
Old Oct 12, 2010 | 09:53 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
I got a set of ZO6 wheels for my 91Z and would like to run 245/45/17 on the front 17x9.5 wheel with 2" spacers and 285/35/18 on the rear 18x10.5 wheel with 2.25" spacers. I've searched this site and haven't found that exact combo. Has anyone ran those sizes and if so how did it work out for ya?
Old Oct 31, 2010 | 12:19 AM
14ZROAD's Avatar
Car: 91 Z28
Transmission: Automatic
Axle/Gears: 3:42
Re: Anybody else running these sizes?
Post pics when you get them on because I was thinking of doing the same.
Old Oct 31, 2010 | 04:23 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Is there a reason you plan on running 245/45-17 on the front on a 9.5" wide rim? I am running 285/35-18 on the rear, but up front I have 18x8s with 245/40-18.
Old Oct 31, 2010 | 07:28 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
The 285/35-18 fit no problem. I am personally thinking about stepping up to a 305 with a bigger sidewall. Your front fitment is small also. I think I have 265s/30 R18. I did not have to do any trimming. I have cut down moog springs and valved Bilstiens. I do a fair bit of autocrossing and road coursing. I have had no problems. I am actually thinking of getting it lower.
Old Oct 31, 2010 | 08:05 PM
I plan on it, but putting it back together from the paint shop at the moment.
The reason I'm going with 17's up front is cause I got a set of stock ZO6 wheels and that is the size, 17x9.5 up front and 18x10.5 in the rear. So I'm trying to get the best size tires on the first try.
I now think I am going to go with 295/35 R18 in the back and still uncertain on the front. I'm trying to get the overall tire diameter close to my current set up and this link has a tire calculator that has helped. http://www.rimsntires.com/specs.jsp?item=Wheel-Tire
Old Oct 31, 2010 | 08:53 PM
dust3r's Avatar
When I had my z06 wheels, I ran 275/40-17 up front, and 295/35-18 in the rear.
Old Nov 1, 2010 | 07:02 PM
Wow a 275 up front. Any issues with rubbing and what size spacers/adapters were you running? If you happen to have any pictures of them mounted, could you post them up?
Old Nov 2, 2010 | 01:50 AM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
thats the way to go.
toronto formula
Nov 10, 2015 06:17 AM
wruiz
Aug 13, 2015 09:07 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
