Spacer lug torque
Car: 91 TA WS6
Transmission: Auto :(
Spacer lug torque
What do you guys that are running 4th gen rims with 2" adapters torque the lug nuts to? (Both adapter/hub and wheel/adapter)
I did a search for this and all I got was arguments
about free body diagrams...so lets stay away from that.
Thanks.
Thanks.
Car: 89 IROC-Z & 92 RS
Engine: 350 TPI & LQ4 408 in the works
Transmission: 700R4 & T-56
Axle/Gears: stock/ LT1 disc 3.42
Re: Spacer lug torque
The adapters should have come with a sheet saying what to torque both at. I put a set of these on a customers car and if i remember correctly the adapter was like 80-90ft lbs and the wheels were normal 100 ft lbs. I will try to check the sheet tomorrow if i get a chance. Plus i am ordering a pair of 2.25 for myself and will need to know as well.
no green
Jan 9, 2016 09:22 PM
