295/65/15 whats it take?
Old Oct 31, 2010 | 09:18 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
i am currently running a hoosier qtp 29/11.5 on a 15x10 with 5.5 bs i was just forced to go up from my 3.73 gear to a 4.11 which picked the car up on motor but its running out of steam on the spray so i want to go up in tire size to kill some gear. with my 5.5 bs will i be able to clear 295/65s without raising the back of the car? i have no problem modifying the inner wheelwell so more but i am not going to cut my fenders. any input is appreciated.
Old Nov 1, 2010 | 11:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: 295/65/15 whats it take?
The Hoosier is
Tire Diameter 29.30 in.,Section Width 11.90 in.,Tread Width 10.00 in.
The only thing i found in a 295/65 is a Et street
Tire Diameter 30.00 in.,Section Width 11.90 in.,Tread Width 10.90 in.
Its alittle over a 1/2" taller closer to 3/4". And the Section width is still the same so you shouldnt have to do any inner/outer fender work.
Old Nov 1, 2010 | 08:37 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i knew that mt made that tire, thats the one i plan on buying i was just wondering what i need to do to make them. they will be about 1/2 taller all the way around
Old Nov 7, 2010 | 08:40 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
noone? i need some assistance. got to get tires pretty quick here and i really dont want to go with the same tire if i dont have too.
fast82z
Apr 14, 2016 08:17 PM
faulball67
Feb 20, 2006 12:12 PM
