deep dish replica wheels/ need help w/sizes
Car: 91 GTA
Axle/Gears: 3:73
can someone verify that i have the correct sizes with out any rubbing.
im hunting for a rim and tire combo's and im interested in the following:
18" c5 deep dish replical wheels chrome
front 1.7" spacer
18x9.5 275/35/18
rear 2'' spacer
18x10.5 295/35/18 will 305/35/18 fit?
wrapped in nitto555
front 1.7" spacer
18x9.5 275/35/18
rear 2'' spacer
wrapped in nitto555
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: deep dish replica wheels/ need help w/sizes
off the top of my head, the may be a little rubbing in the rear, nothing a little hammer work wont fix, but its really hard to give you any soild info without the specs of the wheels, offset backspacing ect.
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Sorry to jumpp into the corvette rims but im wondering if you can tell me what you think about a setup that im going with to see if they will rub im going with the Torque Thrust Black M. They will be 17x8 front with 4.5 backspace and 255/40/17 and rear with 18x10 with 6.75 backspace and 295/30/18....My question is will their be any rubbing or weird things i need i know the rear needs a 1.25 space or something different please let me know???? Thanks
Car: 91 GTA
Axle/Gears: 3:73
as far as off set, all i know is that its for a 4thgen. that in mind ill just need spacers right? 1.7 and a 2" in the rear?
i asked for a 9.5 front
275/35/18
10.5 rear
295/35/18
they want to give me 265 in the front and 285 in the rear in nitto 555 shipped for $1800. not inc duties... good deal??
275/35/18
10.5 rear
295/35/18
Car: 91 GTA
Axle/Gears: 3:73
id also like to look into different wheel companys. if someone knows of companys that will ship wheel tire combos for a good price that would be great.
as far as the y2k's or C5deep dish replicas that im thinking about, should i see if they offer it in my size or just get the 4th gen wheels so if i ever want to sell ill have a larger market?
Car: 87 GTA
Not all 4th gen rims have the same offset, so you need to KNOW the offset of the wheels your using, before guessing & buying parts (adapter spacers).
This page will show you how the offset changes from wheel to wheel.
http://www.skulte.com/adapterfaq.html And cosidering you are looking at a 10.5 wheel, you need to know the wheel specs, since that is not a stock sized wheel. Contact the manufacturer & ask. Should be real simple to do.
Car: 91 GTA
Axle/Gears: 3:73
i recieved an email today with wheel offsets
front 9.5
with a 54mm offset
rear
with a 56mm offset
ive taken your advice and looked at the link youve inc. in your reply, good good info tryed to plug in the numbers but im wondering about this 25.4 number in the example... then mm to inches...?
id really like to find some rims with a deep dish design. if i were to find aftermarket wheels made for a thirdgen im thinking this might creat a larger lip because this room is not taken up for adapter space. you can just look at a stock 16x8 gta wheel and compaire front to back. The front wheels look fantastic. The first day i got my car i noticed this.
front 9.5
with a 54mm offset
rear
with a 56mm offset
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
front 9.5
with a 54mm offset
rear
with a 56mm offset
front 9.5
with a 54mm offset
rear
with a 56mm offset
2.54 cm = 1 inch
Car: 91 GTA
Axle/Gears: 3:73
how do these numbers look?
front wheel
9.5/2 +2.13+ .25= 7.13-5= 2.13 so a 2 inch spacer would work!?
rear
10.5/2 +2.2+ .25= 7.7 so i need a spacer thats 1.7"!?
front wheel
rear
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
275/35/18
10.5 rear
295/35/18
275/35/18
10.5 rear
295/35/18
295/35/18 is the biggest I would go. Its a tight fit. IROCDAN on the SOCAL board has your same exact set up on his 88 grey rag top IROC. PM him and get his info. His car is slammed. Check out this video. Its the Grey Ragtop IROC. http://www.youtube.com/watch?v=FIzl1Q_lfjE
Car: 91 GTA
Axle/Gears: 3:73
can someone help me out with a small list of different wheel size combos. i would like to use 9.5 all around or 9.5 and 10.5 in the rear. the list would have to include proper offsets and require no spacers.
im most interested in some mesh wheels that fit bmw's. theres a staggered combo with 8.5 with 13mm off set and 9.5 with a 15mm offset. in the future im going to contact the seller on ebay to inquire if i can purchase 4 9.5" rims. i think that the front wheels will be too tucked, by about a half inch.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
LT1Formula
Oct 8, 2015 08:34 PM
