Having issues with 19x10 c6 rears
Old Dec 5, 2010 | 06:25 PM
BuiltZ28's Avatar
Hey all, I just got around to putting up my rearend I just built and installing my c6 wheels.
Now I havent had the car on the ground but my setup is a stock width rear with 2.25 rear spacers for the 19x10. I can clearly tell I am going to have some issue with for a lack of better words the lower corner of the interior compartment where rear passengers would sit. I think this may be able to be cut out some and mabey punched in a little to get a little extra clearance. The car has been up on stands for over a year and I was having an issues with the top of the rim/tire hitting on the bump stop area. Will this not be an issue when the car is on the ground and the bump stop is more or less farther toward the center of the rim?
Can anyone tell me some insight on what theyve done for any of these issues.
Old Dec 5, 2010 | 06:42 PM
Stephen's Avatar
Car: 87 GTA
Re: Having issues with 19x10 c6 rears
Trim that corner off, watch for the pinch weld area & not go through it, or you'll be wanting to weld or body-adhesive (stock chassis stuff) the 2 back together.
You can knock that area in some more if needed. I had to knock quite a bit in & trim out more than just that area, because of my 7" bs & no spacers.
The bumpstop will fit more towards the center of the wheel at ride height, but you might encounter rubbing at full axle droop, like when jacking the car up.
Old Dec 5, 2010 | 07:26 PM
BuiltZ28's Avatar
Ok so I shouldnt have to worry about the bump stop area, just that one corner?
Old Dec 5, 2010 | 08:00 PM
Stephen's Avatar
Car: 87 GTA
The corner is almost a guaranteed "problem" area, but hard to say without knowing backspacing/offset info. And is more likely for the tires to hit there, than the wheels themselves.
No guarantee other areas won't hit without work, but nothing is impossible.
Old Dec 30, 2010 | 11:00 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I had the same problem, used a 4thGen rear end, plus hmmm I believe 1/2 inch spacers ? And the wheels wouldn't fit in the back, bumper stop caused the biggest problem, but so did the corner. So don't know if I should buy slightly bigger spacers once I return from deployment ?
Old Dec 30, 2010 | 10:14 PM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
the corner and bumpstop area go away when you lower the car back down...
Old Jan 1, 2011 | 07:19 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
I didn't have much of a problem, just massaged the inner corner a bit with a hammer, didn't have to cut anything using a stock rear and 2" spacers. went i went to an ls1 rear i used a 1/4" spacer
Old Apr 18, 2014 | 07:16 PM
durrettcustoms's Avatar
Bringin one back from the dead here but what did you guys run for springs.....2in drop?
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
nova983
European Region
Nov 2, 2015 12:15 PM
skip91
Sep 22, 2015 10:25 AM
64Chief
Sep 12, 2015 08:05 AM
