stock front tire size 83 trans am/how big can you go
Car: 1983 Trans am ws6
Engine: 305 HO
Transmission: wct5
i have a 83 trans am and im trying to figure out how big of tires i can fit on the front. i am wondering what was the stock size they put on the front and how big i can go.i tried the 265/50s of the back but when i turned they rubbed the inside of the wheel wells. thanks ,eric
Car: 87 GTA
Re: stock front tire size 83 trans am/how big can you go
If your rear tires rub while cornering, you've got bushings issues. Probably worn out & no longer fit tight, allowing things to move in the wrong direction.
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
I think he means he took the 265/50s off rear and tried them on the front.
14" or 15" rim? the sticker on my car says 205/70r14.
I've got 235/60r14s on the front of my 82 trans am with no problems, probably could go bigger but never tried.
Engine: 305 HO
Transmission: wct5
yah i took the 265 50s of the rear and put them on the front. they are 15s.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i cant even find a 265 50 15. they must be taller than stock?
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
original for an 83 trans am was a 215/65/15.
I have 245/50/16 on it now with no rub.
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I have 245's 65 15's on my 91 Formula with the 82 to 84 Stock 15" Turbocast wheels...
No rubbing, fills up wells nice and better traction since it's wider than factory...
Raf
Raf
Car: '82 Z28
Engine: Dart 406 ci
I had 245s on the front and they rubbed on the brakelines. I went to 235s and they fit perfect.
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
knight72
Aug 10, 2015 09:32 PM
