15" rs rims on 87 iroc
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i have an 92 camaro rs i can get a 87 iroc rearend ,posi with 3.73 gears an disc brakes . my question is will my 15 " rs rims fit on this rearend ?
i have searched but couldn't find the answer so if someone with this knowledge would reply i would be very greatfull . thanks
Car: '88 Trans Am GTA
Re: 15" rs rims on 87 iroc
I dont see why not. The bolt pattern is the same as well as the width and those wheels should have no problems clearing the brakes.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Yes they will. Everything is the same.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Engine: l98 tpi
Axle/Gears: 2.77
i could be mistaken on the gear ratio but i was wondering if the 15" rims will work with the disc brakes . my rs has drum brakes i 'm just making sure i can still use the wheels i already have . thanks for your help .
Engine: l98 tpi
Axle/Gears: 2.77
i have an rs camaro i like the wheels i'm gonna paint them black,but i've found a rearend out of a 87 iroc with disk brakes an it's a posi unit which i'm gonna need after i build the 305 an turbo it this spring .
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
That '87 rear may be a borg warner as they were an option in '87 for the iroc's. Their still may be the metal tag on the side of the pot and also all 9 bolts are borg warners. If it is than the ratio will be 3.70's and no fitment issues. There is lots of info on 9 bolts around here as well as tightening the posi and checking the cones. I had one that lasted a ton of abuse for years.
Djmathis123
Sep 29, 2015 01:36 AM
mustangman65_79
Aug 11, 2015 03:17 PM
