front runners or not???
Old Jan 10, 2011 | 10:01 PM
gtpwhite's Avatar
i"m going for a street strip theme, on my 84 Z. about to order some 15x10's for the rear but unsure what i should do for the fronts.
my choices are 15x7's 4"bs or front runner style with 15x4 1 3/4 bs
whats your suggestions? or suggestions?
my only concerns are tire prices for one, stock size i feel will be cheaper, but i think i kinda like the look of drag setup but concerned of how the car will drive (anyone with experience?)
thanks
Old Jan 11, 2011 | 08:02 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: front runners or not???
What rear backspacing did you end up going with for the 15x10 ? Depending on your driving habits will depend on what front rim and tire you want. If you go with the 15x4 say bye bye to corner carving and braking.
Old Jan 11, 2011 | 08:05 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i went with 5" fronts. good streetablity and tires are 205 60(or65) 15, very cheap, common size.
Old Jan 11, 2011 | 08:18 AM
gtpwhite's Avatar
i went with a 5.5 BS i don't want a mini tub right now.
i was going to go with the factory size on the front but they don't offer them in that size...
not even sure if the 4" are the right back spacing
heres what i have to work with 4" 1.74 bs, 7" 4"bs, 8" with either a 4.5 or 5.5 bs
Old Jan 11, 2011 | 08:47 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I had 15x4 wheels up front with a radial tire and it drove GREAT. Kumho Powerstar tires 180/70/15 I think it was.
Relatively cheap at 80 a piece and work well. i've been 130 mph on them. I would not run a bias ply up front.
My other friend runs bridgestone 185/60/15's i think on his street car. The drag wheels with skinnies up front look amazing.
I have 17x4 GTO spares up front now with a bias ply..its alittle soft on the front end and you can feel that when driving.
Old Jan 11, 2011 | 02:54 PM
lb9 GTA's Avatar
Car: '88 Trans Am GTA
Just curious. How much of a gain do you see in your ET with skinnies generally speeking?
Old Jan 11, 2011 | 03:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well the entire 15x8's with 26" ET streets + 15x4 skinnies with those tires above were just over 70lbs of weight savings over 16x8 IROCZ wheels all around with 245 radials with the rear tires with 26" ET streets.
With that I think I saw about a tenth in ET on a low 13 second car. Its about right with the rule of 100 lbs = 1 tenth.
Old Jan 11, 2011 | 11:34 PM
gtpwhite's Avatar
looks like i might go skinnies, one other person to consult then a done deal. does anyone know if that BS works?
i can find a few 185 65's for a ok price
since were on tires any one know the tire rules for the rear?
street tire size, dr size and slicks.
from what i searched everyone try's to squeeze the biggest on on and say it if for me... then other say no way. anyone know for sure?
Old Jan 12, 2011 | 05:47 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I have 15x4 with 1.75 backspacing in the front with Mickey Thompson Sportsman 26 x 7.5-15. Work like a charm.
Old Jan 12, 2011 | 07:46 AM
gtpwhite's Avatar
whats your rear setup?
Old Jan 12, 2011 | 08:06 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
15x10 with a 275/60/15 tire
Old Jan 12, 2011 | 08:18 AM
gtpwhite's Avatar
so would it be safe to say stay under or around a 28" tire for the rears to minimize hammering on the inners?
Old Jan 12, 2011 | 08:22 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The backspacing and tire width matter more then the dia.
With the 5.5 backspacing you have its should stick out even or close with the outer fender so i dont think your going to have to hammer or massage anything. if you have stock suspension.
Old Jan 13, 2011 | 11:35 AM
86sc5's Avatar
Car: 86 sport coupe
Engine: 355
Transmission: 5speed
Axle/Gears: 3.73 detroit locker
I run kuhmo power star 165/80/15 on 15x4's with 1 3/4 bs in front and 275/60/15 nittos on 15x8's with 5.5 bs in back.
Old Jan 13, 2011 | 11:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah that may have been the size I used...165/80/15 power stars
Old Jan 13, 2011 | 12:34 PM
Stephen's Avatar
Car: 87 GTA
.....If you go with the 15x4 say bye bye to corner carving and braking.
Yeah.....I've tried the front skinnies route before & in hard braking, the car would keep going STRAIGHT, despite the wheels being turned!
No more skinnies for me. I'm not looking for every little tenth & compromising to get it.
Old Jan 13, 2011 | 02:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I've been able to lock up the skinnies under hard braking before. Kinda scary. I did that trying to slow down from 140 and hit the 2nd to last turn-off lane at the track and had all four wheels skidding abit but it was controlled. Definately doesnt feel like street tires and normal wheels.
customblackbird
Aug 15, 2021 10:16 PM
tazs2000
Jul 15, 2017 08:44 AM
deracer
Apr 11, 2016 12:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
