16 inch IROC wheels on any 3rd gen?
Old Jan 26, 2011 | 10:30 AM
Guest
Guest
Posts: n/a
Hey guys...I'm new to the forum. Looking to upgrade the shoes on my 1983 Camaro. Question is, will 16 inch IROC wheels fit on my 83? I'm relatively sure that the bolt pattern will be identical, but assuming I might have some back-spacing issues? If anyone knows, would appreciate some insight. Thanks!
Old Jan 26, 2011 | 12:38 PM
Legdiian's Avatar
Re: 16 inch IROC wheels on any 3rd gen?
Don't quote me on this but I believe all thirdgens have the same suspension dimensions. Meaning all thirdgen wheels will fit the same on all thirdgen cars.
Old Jan 26, 2011 | 12:52 PM
Stephen's Avatar
Car: 87 GTA
Yes, they'll bolt right on.
Only issue you could have is the steering stops. They were slightly different for a car built with a 16" wheel. So you may have slight rubbing issues at full turn. Nothing to worry about though. Most people don't change a thing & just live with the slight rub & turning the wheel away, if the rubbing starts. No big deal.
Old Jan 26, 2011 | 01:19 PM
Guest
Guest
Posts: n/a
Awesome. Thanks for the quick answers guys. I figured there would be a good chance they'd mount right up without issue, but wanted to be sure before I dropped the coin on anything. Appreicate it.
Old Jan 26, 2011 | 02:40 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I've run both 15 x 7 and 16 x 8 rims.
Never had any problems, no rubbing at turn and no issues with bump stops.
You should be fine.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
