Correct backspacing and bolt pattern?
Old Feb 27, 2011 | 05:40 PM
LoganKello's Avatar
Car: Trans Am GTA
Hi guys, Im gonna buy some of the following:
Cragar Superspoke 15x7 in front with BFG T/A 225/60/15
Cragar Superspoke 15x8 in back with BFG T/A 275/60/15
When it comes to wheels and backspacing I know nothing so I was wondering what bolt pattern and what backspacing to order
Thanks guys!!!
Old Feb 27, 2011 | 05:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Correct backspacing and bolt pattern?
bolt pattern, 5x4.75, backspacing, rear can be 4.5" to 5", front should be 4-4.5".
the factory 15x7's use a zero offset, or 4" of backspacing, and the factory 16x8's use a little over 5 in the rear and 4.5 in the front.
so to keep the wheels in the same place as your stock ones, you would want 4" in the front and 5 in the rear, but 4.5 in the rear will work just as well and bring the tire out a little more.
Old Feb 27, 2011 | 06:18 PM
LoganKello's Avatar
Car: Trans Am GTA
Awesome Thank you!!!
Old Oct 29, 2012 | 09:11 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Is it possible to run the same backspacing for all 4 wheels? would it be 4.5". and whats the backspace?
Old Oct 29, 2012 | 03:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Depends what width wheeels. An 8" will will fit with 4.5" of bs front and rear if that's what you are asking. Backspacing is the distance from the wheels mounting surface to the back most part of the wheel
Old Oct 28, 2018 | 02:55 PM
superccs's Avatar
Backspacing Explained...
https://www.wheelpros.com/page/offset-explained/9
I just learned something, so you can too :P
Glowsock
Jul 24, 2025 03:15 PM
1992 Trans Am
May 10, 2023 07:19 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
